Bought my first bench power supply, good find or bad find?
rorsch
Joined Sep 6, 2023
18
Hey everyone, I just bought my first bench power supply, it is used, but I found it somewhat cheap(?). It is a Keysight U8002A. I saw from the official website that it is selling for $795, and I found this for around $282 shipped. Is this considered a good find or I should have bought something else with the money?
I know that HP, Agilent, and Keysight formerly were the same company, how was the quality build between each company? Did it deteriorates from Agilent to Keysight, or did it improve?
Last thing, when the PSU arrive, what should I test to make sure that the PSU is working properly?
Thanks everyone!
38,952
Not sure if the quality has degraded since they were HP, but I think it is still likely a high quality supply.
Likely a little overkill for hobby work, but that's okay.
rorsch
Joined Sep 6, 2023
18
apparently the only power supplies that i can find in my country are either the static power supply (the one with 5V 12V terminals output), China knockoffs (pricing around $30~$40, not sure about the quality, never heard of the brand), or pre-ordering some decent one, which will costs me around $1000. As soon as I found this one, I immediately bought it. You could say it's a FOMO perhaps :confused:
Although, now I'm wondering if i should just build a DIY power supply from an ATX PSU. I think I have a used 850W PSU
dl324
Joined Mar 30, 2015
18,524
It's likely a nice supply, but, since you're a hobbyist, you wasted money you could have spent on other equipment.
I bought a couple of these inexpensive Wanptek supplies on AliExpress for about $40 each:
Had to shop around because you can easily spend $50-60+ on them. I waited until there were seller discounts and I could apply "coins". And I wouldn't pay $8-10 for a 4 digit display.
You could have spent the other $200 to get a decent DSO, function generator, bench meter, solderless breadboards, soldering iron, hand tools, etc.
  1. load regulation
  2. output ripple
  3. maximum current
Download the manual and test the specifications you care about.
Isn't it a little late to be second guessing your purchase? You'd only be able to get 12V unless you hacked the supply.
35,307
The power supply I use the most is a 5V 1A supply I built myself.
The next most used PSU is this Power Mate BP76, adjustable 0-12V output.
dl324
Joined Mar 30, 2015
18,524
One of my first projects was a power supply. 4-6V @ 1A and 2.5-19V @ 0.5A in a plain aluminum box. No meters. I added a couple LEDs to indicate overcurrent (that I never implemented), and neon bulb to indicate power on.
WBahn
Joined Mar 31, 2012
33,352
Thanks everyone!
It's probably a good price on a good supply, although all bets are off on a used supply because you don't know how hard it's been abused.
But, as others have said, it is probably much more than you could have spent on a supply the would more than satisfy your actual needs. Hobbyists tend to be tool whores, myself included. It is easy for us to talk ourselves into spending money on tools and equipment that far surpass our actual needs.
Building your own supply has a lot to be said for it. Not only can it be extremely cheap, but it is very educational and satisfying to use equipment that you designed and built. Plus, when it breaks down, you are in an excellent position to diagnose and fix it.
