How to connect this Bench power supply to 220V AC step-down transformer to 12V AC output?
cmpx
Joined Oct 23, 2021
48
This circuit works normaly on +12V DC power supply:
Blueberry PSB400
Yellow wire: +12V, 12.0A, 144.00 W
The Incandescent Bulb, 6V/0.1A is connected to the Bench power supply output.
AC output?
When it is connected onto step-down transformer AC output 10-12V~ the R2 trimmer resistor resistor
is set to 10K.
The Bench power supply circuit is open and I just measure the voltage output
value.
burns up if I try to set R2 from 10K to 0R.
This does not happen if I connect this Bench power supply circuit into the
regulary DC voltage power supply +12V:
Blueberry PSB400
Yellow wire: +12V, 12.0A = 144.00 W
The Bench power supply circuit works normaly.
DC example works normaly.
2-1.pngAC example - R2 trimmer resistor burns up.
The circuit diagram is taken from:1-1-100TransistorCircuits-41-1.png
sghioto
Joined Dec 31, 2017
8,634
You have to include a rectifier and filter capacitor on the output of the transformer before connecting to the bench supply.
That's why it works using the DC power supply.
sghioto
Joined Dec 31, 2017
8,634
What a resistor value calculation should be used for R1 and R2 if I decide to connect it directly into wall outlet phase 220V AC?
Please do not try that!
Doesn't work that way! Major explosion!
Didn't you read my post #2?
Required circuit:
BobTPH
Joined Jun 5, 2013
11,489
Are you just trying to power your DC adjustable supply from line voltage or are you trying to make an adjustable AC supply?
