wowIt works pretty well with the circuit I posted. Admittedly, it is a complex circuit.![]()
realy worrrrrrk
thanks bro
but this is very big and complex
you can make it simple?
In a word....wow
realy worrrrrrk
thanks bro
you can make it simple?![]()
You said twice that the frequency range does not matter, but now you're saying you need the bottom of the range fixed so that 0V gives 0Hz, ie. a flat DC voltage?Exactly
and when
separate control voltage=0 frequency output=0
frequency output must changed by separate control voltage
this is possible?![]()
thanks for answerYou said twice that the frequency range does not matter, but now you're saying you need the bottom of the range fixed so that 0V gives 0Hz, ie. a flat DC voltage?
Back in #7 it was mentioned that you could get a voltage-to-frequency conversion using the control pin (5) of the 555. Is that not acceptable? Bill asked for the map of voltage to frequency that you want.
We're a long way into this thread and still don't know what you want. There are many VCO circuits you can find, but choosing one requires knowing the specifications.
You are misinformed. I don't remember seeing a vco that converts vcc to frequency.thanks for answer
i just want to convert voltage to frequency with 555
but all circuits exist about this just convert VCC to frequency
i want convert my input voltage to frequency not VCC![]()
