555 astable multivibrator-vary duty cycle/maintain freq
danadak
Joined Mar 10, 2018
4,057
Screen shot of right window, what it took to do the design.
Note there is some work to this as Arduino boards have different chips
feeding different pins resources inside part, like what pin PWM is connected
to. So one googles for schematics, etc.
But thats design, why we get paid the big bucks, resolving incomplete
documentation, instructions.....but its all good.
Regards, Dana.
danadak
Joined Mar 10, 2018
4,057
Yes, I am running it on 1.8.8, has to go in this directory
C:\Program Files (x86)\Arduino\tools\ArduBlockTool\tool
You have to create the last 2 elements yourself of the above path. Note
the above directory name is your install directiory for Arduino exe file,
eg. may not match mine shown above. Also typed case of path matters.
.jar executable file that has to go into that folder
http://www.canadarobotix.com/resources/code/ardublock-161216-carobot.jar
Regards, Dana
iONic
Joined Nov 16, 2007
1,662
Nice work danabak!
If the MIT version has more tutorial I may venture there, if not I will PM you for Ardublock.
djsfantasi
Joined Apr 11, 2010
9,237
Compilers, Bascom, Arduino, free, programmer could be Arduino Uno or AVR USBavr programmer.
Yes, to program a chip you do need to learn. Bascom Basic for AVR one of the
easiest, C / Arduino next.
All this is predicated by design goals. 555 timer really crappy on frequency accuracy
and stability, but then many jobs don't care if it oscillates at 1 Hz or 1 Ghz :)
Now you have MIT scratch programming in its infancy. Making a lot of progress, and a
lot of kids working with it in school.
Not only that we have routable programmable with analog micros, where your breadboard is the
micro. You control wiring, and interconnect. I was never a fan of point to point wiring on bread-
boards that were / are tedious, and contact challenged.
Change, its all mostly good.
Regards, Dana.
Here’s another programmer for the ATTiny that’s compatible with the Arduino IDE (documentation included links to the necessary libraries) that may be a better choice.
https://www.sparkfun.com/products/11801
spuddo
Joined May 2, 2013
76
Hi , ionic,hijack all you like , this has produced a wealth of info for me---thanks
I built cct from post#17
Worked a treat with a minor tweak---33kohm between pin 7 and pot---went a bit crazy as the resistance closed in on zero.
no problems using single supply --12V
Danadak thanks heaps for you input----must pull finger and learn to program.
Thanks to all.
Kind regards
eetech00
Joined Jun 8, 2013
4,723
Thanks to all.
Kind regards
Happy it worked...:)
