5 volt 1000 mA regulator or reduction to
Schidtztorm
Joined Oct 1, 2019
77
I'm trying to figure out a way to design a simple 5 volt 1000 mA regulator, or at least a way to drop the 12 volt supply down to 5 volts with 1 Amp. I don't have access to IC's or zeners, so I'll have to use voltage dividers to set voltage. And here's the real kicker! I have to make this with a FET. Enhancement/switcher type. But it's good for many amps, and up to 60 volts.
This is a type of contest between a couple of colleagues of mine and I'm setting them up for it. Lol. I just want to make sure I have a realistic design before I dish it out. They don't think it can be done without risks of frying the gadgets plugged into it.
Can anyone help me with this. If you need the FET info, I'll give it to you, or send you the datasheet. I'm hoping for a general design that will work on most FETs of this caliber.
38,813
Yes, we need the FET info.
If you use a resistive divider from the 12V to generate the 5V, then the 5V value will change with the 12V.
Is the 12V supply stable enough for that?
AnalogKid
Joined Aug 1, 2013
12,273
Without a zener, output regulation will be very poor with a FET. A 7 V differential is more than enough to use the FET as a source follower. But - unlike a bipolar NPN transistor in an emitter follower, a FET has a much less steady gate-source voltage. It is larger (2-3 V instead of 0.7 V -ish); for the same change in load current (for example, 0.25 A to 1.0 A), Vgs varies more than Vbe, creating a larger percentage change in output voltage; it varies way more with temperature, and the device temperature will vary significantly with output current. At 1 A without a heatsink, the transistor will get hot enough to melt your fingerprints.
Without a voltage reference and some feedback, two resistors and a FET will get you sorta-kinda what you want. Two resistors and a bipolar NPN will be better. Two resistors and a bipolar NPN darlington will be best, but with some trade-offs.
ak
38,813
You could use a 2-transistor NPN differential (long-tailed) pair to control a series P-MOSFET.
One differential input is the 5V from the voltage divider and the other is the output 5V.
For proper negative feedback, the MOSFET gate is connected to the NPN collector of the transistor controlled by the 5V from the divider.
That will give good regulation as long as the 12V is stable.
Alec_t
Joined Sep 17, 2013
15,156
If you are allowed or have access to BJTs, normal silicon diodes and passive components you could make a simple switch-mode buck converter.
38,813
Below is the LTspice simulation of a circuit using a P-MOSFET and two NPN's in a differential stage.
The output voltage is proportional to the input voltage, with 5V out for a 12V input.
Schidtztorm
Joined Oct 1, 2019
77
I'm not familiar with those
I have standard rectifier diodes. I might be able to find a bit, bit nothing big enough to withstand 7 watts. The big FETs are all I have that can hold it.
I posted the get info above. Could you send me a schematic?
Schidtztorm
Joined Oct 1, 2019
77
Thank you for that. Though your schematic isn't clear (it's distorted) but I'm familiar with that type of regulator. And you are absolutely correct. I just don't have access to any big BJTs. Only the FETs. Is this hopeless? The 12 volt supply is extremely stable. (switcher type)
Is there a way to make the above power FETs work with resistive voltage dividers?
38,813
Looks fine in my post.
You could use the N-MOSFET as a source-follower with the gate connected to a resistive divider (one resistor being a pot so you can adjust the voltage to the desired value.
The voltage output will be somewhat sensitive to load and temperature.
LTspice simulation of example circuit below for load varying from about 1A to 0.1A:
Schidtztorm
Joined Oct 1, 2019
77
Thank you so much for that. And your attachments no longer look distorted. Must have been a bad loggin or something.
Can I use a voltage divider instead of a potentiometer. If so, what voltage do you think is best. I'm not sure of the voltage drop from the gate source. Is it going to vary a lot? What do you think the tolerance is on a cell phone voltage wise?
