4017 Frustration
BobTPH
Joined Jun 5, 2013
11,664
Will it keep good time?
Touché.
Add a crystal and two more caps if that is a consideration. I think the TS mentioned a 555 based clock, but maybe that was a different thread.
Edited: I see he said 4060, which, like the PIC, can use an optional crystal.
electrongod1
Joined Sep 8, 2018
40
I use an old free version of Eagle (4.13r1). The pull-up resistor can be 10k.
I'd use counter chips to make mod 60 and mod 12 counters.
For the minutes/seconds LEDs, I'd use the LSD counter and convert the outputs to decimal. For instance, using CD4029 as the counter (because I happen to have some) and CD4028 BCD to decimal decoder. That handles LEDs representing 0-9. Then I'd use the MSD counter with another CD4028 to decode 0-5 and use that to drive 6 banks of 10 LEDs.
For minutes (or seconds), 2 CD4029 and 2 CD4028.
Dennis, What do you think about using 4013 between 4017s to toggle signal?
electrongod1
Joined Sep 8, 2018
40
The problem is that one LED will always be on whenever a CD4017 is enabled. So you can't use the Q0 output when the counter isn't disabled.
It was how you labeled the LEDs.
RGB LEDs will complicate the circuit I posted. I could use a single current limiting resistor for all 60 LEDs. Plus I'm switching both the anode and cathodes of the LEDs. You can't do that with RGB LEDs.
What do you thing about using 4013 to toggle signal between 4017s?
panic mode
Joined Oct 10, 2011
5,313
single LED on is boring....
if i was going to do this, i would use MCU, something like ESP32 so it can use WiFi to get real time from the internet. the only other IC would be some sort of led multiplexer ic such as MAX7219 or whatever. then you can have not just precise clock that never drifts but also various effects... like instead of simple increment to next LED, how about comet zooming all around before stopping at the next led. or display inverted... or as pie chart... or whatever... or add photoresistor and you can have automatic dimming so that LED is not disturbing your sleep.
or... how about no multiplexer IC. just use addressable LEDs. then you can have any color you want...
and for those afraid of SMD, there are though hole variants like WS2812-F5 / WS2812-F8 , APA106, PL9823 ...
electrongod1
Joined Sep 8, 2018
40
I'm not sure you've considered all of the ramifications of using the same LEDs for hours, minutes, and seconds.
Yeah i get it. So at 12 o'clock the first led is red while leds cascade blue around the clock in seconds, when it reaches 12 oclock the red will turn violet for a second and second led will turn green. I get that at 12:05 the corresponding led will be yellow, and white for a second. My thought process is to use cd4060 for seconds/minutes/hours and 6 4017s for seconds, 6 4017s for minutes, and 2 4016s for hours if I can get them to work dammit. By the way dont let my user name fool you, Im a retired electrical contractor and it was a nickname my co-workers gave me.
28,457
Thanks for your input. Ultmalely I want to build a 12 hour clock with 60 rgb leds, blue -seconds,green -minutes, and red hours. Im old fashioned and retired, so no microproccessors please, Ive got a lot of time on my hands. I stumbbled on the idea when I unpacked my scope and was looking for a circuit to play with it on, then I ran into 4017s and was intantly enamored. Im going to be using CD4060s for my time base and 4013s attain the correct frequency. A lready have an oscillator runnig on my circuit thats running prfectly. The circuit I posted is to help me better learn the 4017 and if my idea is plausable Sorry to bore you with all this but hopefully you'll better understand where Im comming from. Thanks again.
Aside from the time base,decoding and driving the display are the big challenges, with vastly different levels of complexity and parts counts.
schmitt trigger
Joined Jul 12, 2010
2,260
The beauty about electronic clock circuits, is that literally there are several dozens of circuit variants.
You already have received a wealth of suggestions. Thus the only thing I would add, is that you should definitely consider multiplexing your display, to keep the amount of wiring and discrete components to a sane level. The example in post #30 by DL234 is a good one.
dl324
Joined Mar 30, 2015
18,479
You mean separate clocks for seconds, minutes, and hours instead of having seconds drive minutes, and minutes drive hours?
It would be helpful if you showed a schematic or block diagram for this. If you drive the LEDs using the circuit in post #9, 6 isn't enough. If you multiplex them as I did in post #30, 3 should be sufficient. But, you can't do that because you want to use RGB LEDs.
BTW, how are they wired? Common anode? Common cathode?
How can analog switches be used for hours?
panic mode
Joined Oct 10, 2011
5,313
multiplexing is simple but regardless if using single IC like in post 48, or several ICs like in post 30, there is going to be a lot of traces to take care of. the lowest part count and simplest routing is to use addressable LEDs. then PCB layout becomes trivial:
panic mode
Joined Oct 10, 2011
5,313
exactly...
keeping good time using crystal is ok though it will still drift a bit. to completely get rid of drift one can use internet time or atomic time receiver.
atomic clock receivers are not expensive but are antenna is directional. and since every household has internet, that is why i proposed using controller with WiFi built in. an overkill but low cost and low parts count...
plus plenty of muscle to do anything fancy for special occasions like birthdays, New Year, whatever...(heartthrob, comet, party mode...)
