- Joined Jan 23, 2018
- 28,636
If you research this site you will see the circuits, some of them are quite brilliant.
I missed that fact. But you can still do 60 by simply resetting the second counter after 60.TS wants to build a clock that 60 LEDs.
An MCU is still the simplest solution.
Thanks for your input. Ultmalely I want to build a 12 hour clock with 60 rgb leds, blue -seconds,green -minutes, and red hours. Im old fashioned and retired, so no microproccessors please, Ive got a lot of time on my hands. I stumbbled on the idea when I unpacked my scope and was looking for a circuit to play with it on, then I ran into 4017s and was intantly enamored. Im going to be using CD4060s for my time base and 4013s attain the correct frequency. A lready have an oscillator runnig on my circuit thats running prfectly. The circuit I posted is to help me better learn the 4017 and if my idea is plausable Sorry to bore you with all this but hopefully you'll better understand where Im comming from. Thanks again.A lot of it comes down to what is it that you are trying to accomplish? If you are trying to learn how to use a 4017, then using something else won't accomplish that. But if you are just trying to make some kind of LED chaser, then using a different approach may be the way to go.
Also, if all you want is a chaser for some reason, then there are LOTS of LED chaser circuits on the Internet (and some of them actually work). But if your goal is to understand how to design a chaser, that's a completely different critter.
Also, there isn't a single "simple chaser" -- lots of variations, so you need to clearly understand (and communicate to us) exactly what you want your simple chaser to do. Without that information, telling us that something functioned as planned doesn't tell us much.
Thanks for cleaning thing up Dennis. What software did you use, and what size pull up restor at pin 13?That's an awful "schematic".
Redrawn:
The 2Hz signal also needs to be connected to pin 14 of IC2. Pin 13 of IC2 needs a pull-up resistor. The LED labeling must be wrong.
I use an old free version of Eagle (4.13r1). The pull-up resistor can be 10k.Thanks for cleaning thing up Dennis. What software did you use, and what size pull up restor at pin 13?
I'd use counter chips to make mod 60 and mod 12 counters.I want to build a 12 hour clock with 60 rgb leds, blue -seconds,green -minutes, and red hours.
That's a VERY incomplete schematic. It strongly implies that you are driving the LEDs direction from the 4017 outputs, which is all-but-guaranteed to cause issues. You've got no bypass capacitors on your ICs. You have four signals coming out of what appears to be a transistor.Finally here is my updated chaser circuit. Now leds 1-10 cascade as planned while led #12 stays on, On the 11th cycle, 1-10 Chase fine and after #10 lites up on its last cycle 11 and 12 alternately blink rapidly. This goes on for a few cycles and reverts to 1-10 chase while #12 stays on.View attachment 367305s to 10-10 chasing normally while #12 Stays on. I guess im getting closer. Thanks for any help.
Thanks again Dennis, I'll look into your idea!I use an old free version of Eagle (4.13r1). The pull-up resistor can be 10k.
For the minutes/seconds LEDs, I'd use the LSD counter and convert the outputs to decimal. For instance, using CD4029 as the counter (because I happen to have some) and CD4028 BCD to decimal decoder. That handles LEDs representing 0-9. Then I'd use the MSD counter with another CD4028 to decode 0-5 and use that to drive 6 banks of 10 LEDs.
For minutes (or seconds), 2 CD4029 and 2 CD4028.
I’ve not drawn the other 54 LEDsThe advantage of using up/down counters is that you can add switches to set the time. With CD4017, they can only count up.Thanks again Dennis, I'll look into your idea!
Dennis, I added a pull up resistor as you suggested and Im getting closer. First 10 laed cycle fine while #11 stays on, after led #10 turns on #11 turns off and #12 turns on and cycle repeats itself. Also in your diagram you are only showing 7 leds on 4017 #1 with 3 outputs tied together. Was this out of necessity or because of my crappy drawing. Thanks again, Frank.Thanks for cleaning thing up Dennis. What software did you use, and what size pull up restor at pin 13?
Wow! Identical with I am trying to do, less the digital display. In a nutshell 60 rgb leds, blue-seconds, green-Minutes, and red-hours.The advantage of using up/down counters is that you can add switches to set the time. With CD4017, they can only count up.
You could also decide to supplement the time display with 7 segment LEDs.
I once thought about building something like this (though I planned to have the circuitry represent circuit blocks: counters, decoders, etc):
The guy (I assume) included magnetic switches for setting the time.
It will work with both my circuit and @dl324 's provided you use the RGB LEDs with 6 pins where cathode and anode for each LED are brought out independently. If you have common cathode or common anode LEDs it's going to take a lot more circuitry!Wow! Identical with I am trying to do, less the digital display. In a nutshell 60 rgb leds, blue-seconds, green-Minutes, and red-hours.
Frank
The problem is that one LED will always be on whenever a CD4017 is enabled. So you can't use the Q0 output when the counter isn't disabled.I added a pull up resistor as you suggested and Im getting closer. First 10 laed cycle fine while #11 stays on, after led #10 turns on #11 turns off and #12 turns on and cycle repeats itself.
It was how you labeled the LEDs.in your diagram you are only showing 7 leds on 4017 #1 with 3 outputs tied together. Was this out of necessity or because of my crappy drawing.
RGB LEDs will complicate the circuit I posted. I could use a single current limiting resistor for all 60 LEDs. Plus I'm switching both the anode and cathodes of the LEDs. You can't do that with RGB LEDs.Wow! Identical with I am trying to do, less the digital display. In a nutshell 60 rgb leds, blue-seconds, green-Minutes, and red-hours.
Will it keep good time?I can do it with 3 parts, plus the LEDs. An 8 pin PIC, one resistor and 1 capacitor. The 60 RGB LEDs will be WS2812B addressable LEDs. And the wiring is trivial, 3 wires daisy chain all the LEDs
| Thread starter | Similar threads | Forum | Replies | Date |
| D | HELP WITH 4017 RESET | General Electronics Chat | 29 | |
| O | Using 2 decade counters CD74HC4017 to make it count 20 | Homework Help | 16 | |
Improvement for digital lock project using IC4017 | Homework Help | 15 | |
| K | Decoder encoder using 4017 with IR LED For transmitter | General Electronics Chat | 14 |
