Improvement for digital lock project using IC4017
Danyang
Joined Dec 21, 2025
7
Hi everyone, i'm currently processing a project about simulating a digital lock. In my project, i use 2 IC for basic functions like checking password, alerting, controlling relay. I do think that my project have some major problems so i go here to get instructions.
First, my project can not check the order of the right password. For example, if i set the password '1234', and i enter '1256' or '4321' the buzzer will not work. It only works if i enter 4 of those numbers 5 6 7 8 9 0.
Sencond, i do think i that my project needs improvement because uing 2 IC 4017 is a little bit simple.
This is my very first time of designing circuit and digital system so please give me instrustions and comments for improvement.
Thanks for your helpful advice
dl324
Joined Mar 30, 2015
18,495
Welcome to AAC!
Is this project for school? If it's schoolwork, post the complete text for the problem.
Turn off that awful grid. You aren't using it anyway. Remove unnecessary wire jogs/whitespace.
Danyang
Joined Dec 21, 2025
7
Welcome to AAC!
This is my school project. Lecturer only requires simulation on Proteus.
dl324
Joined Mar 30, 2015
18,495
Post the complete text for the problem.
I'll flag your post to have it moved to the Homework Help forum. You'll be expected to do most of the work there as members can only offer guidance.
Danyang
Joined Dec 21, 2025
7
I am designing a simple electronic combination lock as a student project.
The design must not use a microcontroller and should rely only on basic logic ICs.
Danyang
Joined Dec 21, 2025
7
Are you required to use only the 4017s?
No, there is no limitations in hardwares selection as long as they are digital one. The only constraint is that i can not use microcontroller. I do try using only logic gates then improving by using DFF but finally i chose to use 4017 because of its ultility.
ericgibbs
Joined Jan 29, 2010
21,637
Hi Danyang,
I have moved your thread to the Homework forum.
Use the methods and diagrams that the Teacher has stated must be used.:)
Moderator.
sghioto
Joined Dec 31, 2017
8,760
There is a way using U9 4017 to activate the buzzer if the code is incorrect.
U9 needs to get pulsed regardless of which button is pressed.
Figure out how that would be accomplished.
If the correct code is entered, what is the output on U7 and U9?
What is the output on U7 and U9 if the code is incorrect?
Danyang
Joined Dec 21, 2025
7
Thank you. I will try but it seems kinda abstract to me
sghioto
Joined Dec 31, 2017
8,760
Think about this, if U9 is wired to receive a pulse regardless of which button is pressed after 4 presses the output on U9 would be what?
