24V 5A 3-state capacitive touch switch (not a dimmer, without relay)
oslosl
Joined Jan 13, 2023
270
Laying out circuit boards is like a puzzle. You want to position components to permit short, direct paths as much as possible.
High current paths are the most important, which in this case is the high power connections between the MOSFETs and the power connector. Ideally, they will be located adjacent to each other with short connections.
The other place short connections are best is the bypass cap for the chip. As close to the power pins as possible is the goal.
You can use both sides of the board to route tracks with vias connecting top to bottom. The soldermask will insulate the board from the metal trim. You might add a thin layer of insulation, like a piece of overhead transparency material, to be safe. Bit no through-hole components in this design.
Thanks. Do I have to use multiple vias for 5A ?
oslosl
Joined Jan 13, 2023
270
Did you watch the tutorial I linked in post #221? Yeah, I didn't think so.
I have watched the tutorials, but I can not find anything about why I am hanging in Component Placement forever (see screenshot).
This is right after I have selected PCB Assembly, added BOM and CPL file, confirmed BOM data and it hangs like this.
Jon Chandler
Joined Jun 12, 2008
1,643
Use large diameter vias for high-current Tracee.
Describe exactly what you're doing to get to the point where you're stuck. I don't know where you're at.
oslosl
Joined Jan 13, 2023
270
Just ordering PCBs work fine, but PCB Assembly hangs.
Jon Chandler
Joined Jun 12, 2008
1,643
You need to provide way more detail about what "not working" means. I don't think there are many mind readers or fortune tellers in the forum.
I do recall saying that the resistor/capacitor values might need some adjusting, but since I don't know what "not working" .means, it may or may not be your problem.
Searching for "4017 power on reset" may give you some help.
Jon Chandler
Joined Jun 12, 2008
1,643
You really need to explain things FULLY. Otherwise, no one is going to even try to help.
1. Circuit counts to 10 instead of 3 and starting over? How do you know?
□ yes
□ no
2. Power-on reset always resets counter back to zero when circuit is powered up?
□ yes
□ no
3. Circuit does anything else screwy that you don't think is important enough to mention?
□ yes
□ no
4. You used ALL the parts in the schematic I made for you and made all the connections without changes, including the ones you didn't understand?
□ yes
□ no
If you had spent 5 minutes providing some explanation, I wouldn't have spent 30 asking for more details.
oslosl
Joined Jan 13, 2023
270
1. Yes - tested it and counted.
2. Yes
3. No
4. Yes, but used 4148 instead of 4148w, LP2950 instead of TP2202-5.0YNEG and 2N7000 instead of 2N7002 because I already had them.
Jon Chandler
Joined Jun 12, 2008
1,643
So what makes the counter reset to zero when it reaches 3? Please engage your brain and think about what should happen vs. what is happening.
28,224
I have breadboard tested the curcuit and it looks like the reset function for the 4017 is not working. Please advice ?
Which reset function? The "after both on" reset to both off, or the power on reset so that when initially powered on, all is off???
Jon Chandler
Joined Jun 12, 2008
1,643
I think in post #270 & #271 I managed to elicit that the POR works ok, but the reset when the count of 3 is reached doesn't happen.
It's unfortunate that it's required so many messages to (maybe) translate "it doesn't work" into something actionable. And it's also unfortunate that after 14 pages in this thread, operation of the 4017 still isn't understood well enough to troubleshoot a connection between two pins with a single component between them.
Sigh.
28,224
Like I commented, C3 is quite a burden, so how about a diode in series with the power-on reset circuit, so that the capacitor does not slow things down so much. Using a "diode OR" function DOES require diodes in all of the inputs. There is probably a maximum allowable rise time on the reset input at lower supply voltages. Probably there is a maximum rise time specification for the reset input.
