- Joined Jan 23, 2018
- 28,212
Have you tried putting a series inductor, (filter choke) in series with the power supply positive to the amplifier??
Suggested values for 24V 5A ?Similar to what is shown here BUT on the OUTPUT side of the power supply, because the symptom is that the supoply is adding the noise.
Good idea. Will doWondering if the problem is the BT. Have you tried running the BT on battery power? Specs say it can run 3.3volts so a 3.7 volt lipo would be ideal.
