AlbertHall
- Joined Jun 4, 2014
- 12,663
Well, that's why it doesn't work. That voltage is much too low.Sorry, yes I measured that voltage. Thats the max the cap got to.
You might try lifting one end of the cap, cliplead in a 400V cap (any value), and see what voltage it charges to.Sorry, yes I measured that voltage. Thats the max the cap got to.
You might laugh at this - Sadly I don't have any. I don't have many components at all. Im just trying to fix this up for my unlceYou might try lifting one end of the cap, cliplead in a 400V cap (any value), and see what voltage it charges to.
I checked, but didn't find anything corresponding.Check the capacitor against the pdf here: https://www.hificollective.co.uk/components/fandt-axial-capacitors.html
Well, that makes it rather difficult to troubleshoot the circuit. :-(You might laugh at this - Sadly I don't have any. I don't have many components at all. Im just trying to fix this up for my unlce. Sorry.
Could I simply use some eBay cob LED chips?To replace with LED's you would need a number of high-brightness LEDs facing in both directions for the double-sided flash lamp.
You likely will have to experiment to determine how many is required to give sufficient light (especially if it must be visible in sunlight).
Cree, for example, is a large supplier of high-brightness LEDs, including amber output types.
Once you determine how many you need, then a circuit can be designed to flash the LEDs.
For best efficiency since it's battery powered, you could charge a capacitor with a resonant inductor circuit and then discharge the capacitor through the same inductor into the LEDs.
Such a circuit should be able to put about 80% of the battery energy into the LEDs.
| L | LED Flasher Help | Digital Design | 20 |
| Similar threads |
| LED Flasher Help |
