Sparky49's Blog
So I've been learning how to produce chiptunes. You know, the synthesised music from your C64 or NES. So far I've done two tunes, using two programs. One is famitracker, which emulates specific ICs. In this case, I wrote out Bach's Praeludium Nr. 2, which is emulating a Konami VRC6...
Sparky49
Views
1K
2
This may seem a bit cryptic at the moment, but all will be revealed in a couple of weeks. :D If you had a choice, which would you pick - high or low? Leave your answer as a comment below. Many thanks for your help. Sparky
Sparky49
Views
1K
1
Sorry guys. :p All will be revealed in a couple of months. ^-- confirms http://chemglobe.org/ptoe/_/18.php http://chemglobe.org/ptoe/_/2.php Argon comp on RHS.
Sparky49
Views
1K
2
Okay a little rant.... We have a design exercise to do in uni - it is a PIC based counting circuit, which counts the number of objects passing between a light source and an LDR on a conveyor belt. We were told that there should be a circuit built from op amps to convert the analogue signal...
Sparky49
Views
943
1
I've been at uni for more than five months now. Not once have I seen a soldering iron. I've used a breadboard twice though. This is engineering, not theoretical electron management. :P
So, here's the thing. Got coursework due in on Friday. Lots of work set, really too much set to do during the time allotted each week (seriously, not typical student excuse). So here I am. Not too much to do now. Mainly organising it. What good is a tidy logbook? Logbooks should be...
Here's the first set, chaps. Please read the introduction post. Thanks!:) 1.9 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 1.20
Hi all. Thanks for taking the time to help me with the questions to produce the world's first Art of Electronics Answer Guide. Yay! I intend to post questions up here. Any which need a schematic or formulae from the book will have that too. In order to avoid people doing the same...
Sparky49
Views
1K
1
No questions to answer this time! I had an hour last night to begin reading through the book I bought. The first chapter served, as one would expect, as an introduction to the concept of the microcontroller (from now on uC) and gave a basic layout and description of the parts which make up a...
Well, a lot of views for my first post, and I'm very grateful and happy some people have found it useful! Even rated 5 stars! What I'll do is address any questions I recieve, by PM, email, on the forums or even as a comment at the beginning and then add the new post. Questions from #1: 1...
Sparky49
Views
2K
2
I hope that this blog will serve many people who, like myself, could not find a definite and easy to understand list of the needs and the progression towards learning to program a microcontroller. In this, my first post, I will talk briefly about my time trying to find a microcontroller to...
Blog information
Author
Sparky49
Blog entries
12
Last update
Share this blog
