I’m attempting to confirm my approach to this project circuit. I’m wondering if the 2 halves of the circuit (as shown) would work well to drive the Load, or even work together well at all. (It’s been a while since I was designing circuits (30+ years) and I’m a bit rusty.)
I’ve done a preliminary drawing but many of the details like Current and Component values are still either missing or a best guess at this point.
I have 3 questions really:
1. Is using Zener Diodes as I have done an appropriate approach for regulating/providing the 4 different voltages I need? (as shown) I am yet to work out the values but I want to check my approach is correct first.
2. Are the Amplifiers needed in addition to the Buffers (Emitter Followers) after the Frequency Generators? I suspect that the amplitude of the signals may be sufficient without them.
3. Is there a better approach I should use instead?
Circuit Purpose
To generate a variable frequency of approx. 10KHz (±50%), at a variable range of amplitudes. An isolated circuit is the Load. (See circuit)
Regulate 36V DC to generate 5v (Circuit Vcc), 12v DC, 24v DC & 36v DC.
The 12v, 24v & 36v circuits each provide an approx. 10K Hz, 50% Duty Cycle wave. I’ve used Hex Inverters with Schmitt-Trigger Inputs to achieve a really square wave. (See circuit)
The Load is an Isolated Circuit that contains a step-up transformer (1 to 10) that feeds a large capacitor in a very poor dielectric solution. The diode D12 stops the capacitor from discharging during operation. Once charged, the current in the Isolated circuit is very low.
Only one signal is connected to the Load at a time so I’ve used 4 x switch DIPs to select the appropriate connections. Changes to switches would be made only when the power is off.
The same earth is used throughout.
Circuit Purpose
