Oscilator circuits -Zener's voltage & potentiometer's Ohm
svanslund
Joined Jun 1, 2021
schmitt trigger
Joined Jul 12, 2010
2,276
From the website:
R6 and ZD1 provide a form of amplitude limiting by preventing excessive signal swing and reducing clipping after the oscillation has stabilized.
I would start with a zener a little less than half the supply voltage. Powered from a 9V battery, I would select a 4.3 volt zener.
28,509
BOTH of the variable resistor values are given The setting is done to provide the desired operation, so YOU have to adjust them. But if the associated text does not mention the zener voltage at all, then you may need to experiment.
A fair guess is about half the supply voltage. You could experiment with a string of forward biased silicon small signal diodes, (1N914, or even 1N4001 series power diodes. Whatever is cheap or on hand.
28,509
What was not mentioned were how muchdistortion is allowed and the desired frequency stability, and the consistency between units, if they are for production. The two transistor oscillator appears to have 2 resistors and two capacitors affecting the frequency and distortion, while the single transistor oscillator has three of each that affect the frequency but only one resistor affecting any distortion.
