Checking zener diodes
Rufinus
Joined Apr 29, 2020
325
Hi, I have a batch of SMD 2,4V 0,5W zener diodes. 5% tolerance (they are from a good supplier)
It is my first time checking zener diodes.
I put in series with 1K resistor and the positive to the cathode.
These are my readings Vi is the power supply and Vo what I get with the DMM (also it is a good multimeter and a good power supply)
Are ok these numbers? I thought the diode should give the same voltage than te power supply under 2,4 volts and over 2,4 volts the voltage across the diode should increase slower.
Thank you
Best regards
WBahn
Joined Mar 31, 2012
33,316
Could you please go back and edit your first post to clean up all of the typos. It's making it very difficult to be sure what you are saying.
Also, please provide a sketch of your circuit and identify where you are taking your measurements. Vo is measured from what to what?
Do you have a part number for the diode or, better, a link to the data sheet?
ronsimpson
Joined Oct 7, 2019
4,856
The data sheet will tell you how the factory tested the part. Maybe at 5mA. (depends on the size of the diode)
Here is a page showing how this diode was tested at 5mA, and 1mA and 30mA.
My guess is that Vin is the voltage across 1K resistor and the diode. Adjust the power supply so approximately 5V is across the resistor to make 5mA. (5V on the resistor and 2.5V on the diode = 7.5V) Now you should have the 5mA.
Note this is at 25C
This graph below shows the voltage and current for different diodes. High voltage Zeners are OK, low voltage Zeners are not good. A 5V Zener has a very flat V verses I curve. A 12V Zener has about the same voltage a 0.01mA and at 10mA. A 2.4V part changes voltage with current. 1780319061447.png
Hope this helps. RonS.
panic mode
Joined Oct 10, 2011
5,426
also note that zener diodes are not ideal... specially ones for lower voltage. here is an example of 5.1V diode and using variablle input voltage.
note that 5.1V output is not very firm... and it increases with zener diode current.
dl324
Joined Mar 30, 2015
18,491
You misunderstand how zener diodes work.
You mention that your diode is 2.5V, then mention 2.4V above. Here is the data for 1N5321 and 22 (the B suffix indicates 5% tolerance):
Note that the nominal voltage is specified at Iz. For 2.5V (and 2.4V) zeners, that's at 20mA. You never get to that current in your "tests".
The knee of lower voltage zeners isn't very sharp, so operating current is more important than for higher voltage diodes. At 20mA, a 5% tolerance 2.5V zener diode can be 2.375-2.625V.
panic mode
Joined Oct 10, 2011
5,426
and if you are really into getting sharp response, usual remedy is to keep the current through zener low and more or less constant. the other issue with zener is that voltages come in certain "step" sizes. if you need to tweak it, or want sharper response curve, consider using some circuit rather than simple diode. here is an example of using BJTs as zeners. zener voltage is set using R5/R9/R14/R20 etc resistor.
it is easy to see that increasing number of transistors results in flatter curve. variant with 2x BJT is comparable to real zener.
in principle one can add one or two more stages
38,915
Those circuits are, of course, temperature sensitive, with the voltage dropping by about 0.3%/°C due to the change in the Vbe of the transistors.
You can make a low voltage, adjustable Zener type circuit with a sharp break and a very flat, stable voltage using the programmable TL431 or TLV431 inexpensive voltage references along with three resistors.
Below is the LTspice sim of an example circuit using the TL431 configured to give a 3V output (yellow trace):
The TL431 starts to conduct when the REF voltage (red trace) reaches 2.5V, as determined by the voltage divider resistors R1 and R2.
If you eliminate R1 and R2, and connect REF directly to the TL431 cathode, the output will be a regulated 2.5V.
Rufinus
Joined Apr 29, 2020
325
Thank you all for your help and advice.
Sorry about the typos. I was in a hurry, I should have took my time to write the post.
I put the resistor in series with the diode and I took the readings from the diode, but yes, never reached the 5mA until I reaise the voltage well above the rated voltage.
I have repeated the test with a 12v zener and now the results are much more consistents
Here is the datasheet
https://www.tme.eu/Document/1dd0f6c2590b3fd6eee870cea0ed49a7/BZX55_SER.pdf
dl324
Joined Mar 30, 2015
18,491
I don't trust it.
They give a range of 2.28-2.56V for a 2.4V zener but 105% of 2.4V is 2.52V. The range for the 2.7V zener is 2.5-2.9V, but it should be 2.56-2.84V. Unnecessarily sloppy work; probably don't know what they're doing.
I wouldn't call them a good supplier.
28,510
I have used the FORWARD VOLTAGE DROP of smaller power diodes as a shunt regulator on a few occasions. It is reasonable in a "one-off" instance, but probably not cost effctive in production quantities.
But the efficiency is similar to what you get with a zener, and for many applications the tolerance is better, at least beyond the point of initially going into conduction.
WBahn
Joined Mar 31, 2012
33,316
What is the purpose of your tests? What is it, exactly, you are trying to determine and, if possible, why is it important?
It could be that your test isn't going to really tell you want you think it is.
ci139
Joined Jul 11, 2016
2,037
… batch of SMD 2,4V 0,5W zener diodes …
… Are ok these numbers …
looks pretty there …
what you must realize - is that the reverse biased Zener or forward biased https://en.wikipedia.org/wiki/Stabistor or LED simply have a more abrupt slope change at their I-V curve than conventional diodes
they don't have item-to-item matching curves over the produce
they are not voltage references as TL(V)431 etc. ...
however you can build one feeding it with CC
the 5% likely means the inter device deviation of the referenced voltage at reference current point
which also does not mean that some items may not reside outside the 5% range -- unless such are removed by selection process
28,510
The summary , as I see it, is that zener diodes are basicly not precise , and so not suited for use in circuits requiring close tolerance without adjustments.
A zener is handy for clamping voltage peaks in higher-impedance circuits. And a reasonable choice for a voltage reference that does not need to be "really close". That includes the 5 volt power supply for most digital logic. NOT "5.00 volts", though, just "5 volts" , allowed to be off a small amount.
Rf300
Joined Apr 18, 2025
131
I just wanted to check the voltage since there is no voltage indication in the diode
Take a power supply of 15 V, add a series resistor of 1 kOhm and then the zener diode to be measured. This will provide a current of 3 to 10 mA for zener diodes from 12 to 5.1 V. You can simply measure the voltage across the diode. This setup has sufficient accuracy to determine the nominal voltage of the zener diode. If your measurement is higher than about 12 V, you can increase your supply voltage to maybe 20 or 24 V.
