Yanmar Diesel Engine
R!f@@
Joined Apr 2, 2009
10,011
Bolt head gone for good.
After a lot of coke and thinner and getting high with fumes I manage to get it open.
I was able to get the thread out but I need a drill press to drill through the tuck bolt piece. It's in machine shop now..
So checking on then semi's now
R!f@@
Joined Apr 2, 2009
10,011
Negative plate bolt broken, Not even a connection :eek:
I'm referring to debe's diagram
Tapped for tacho ..
But one problem..I found this bugger inside
It's a cap but for what...??
It's wires cannot be found or I dunno where they went or dissolved but what is that cap for ?
By the way, How do I test the circuit ?
shortbus
Joined Sep 30, 2009
10,049
Maybe the cap was part of the tach signal? You know, block DC and pass AC?
Thought you got a new alternator, this one doesn't look too new. :)
debe
Joined Sep 21, 2010
1,419
This is how i bench test altenator regs. Note the Ind lamp must be no more than 2W. The globe across where the rotor/brushes can be about 5 or 10Watt. Using an adjustable powersuply feed power as shown. If the Reg is working ok then the globe where the rotor was should be On with 24V & go out at about 28V. (iwill be out for the next 6Hrs). Also no idea why theres a Capacitor inside. Some time there is a .5uf cap externaly on the B+ to stop altenator whine in radios.
R!f@@
Joined Apr 2, 2009
10,011
U know these stuffs well Daryl..!
Thanks a bunch ..The Info u provided helped all thru out...
I tested 'em and Rectifiers and the Reg is A-OK.:D
I assembling it now.. post back later.
R!f@@
Joined Apr 2, 2009
10,011
or it could be connected across the Lamp ...I dunno..:confused::confused:
I am getting rid of it..!
R!f@@
Joined Apr 2, 2009
10,011
Finished the Alternator
My way of testing the alternator :D
The Lamp Voltage shoots to 22V, Could not run too long. too much wobbling.
RPM works like a charm.
I think the charge lamp is now blown. Told em to check it. We'll know a few weeks later I guess.
Thank you all for all the help. Specially to Daryl.
You guys makes my jobs definitely much easier
R!f@@
Joined Apr 2, 2009
10,011
U know I finished it.
Still no pay. :(
Guess what, they are not answering my calls. Been calling them yesterday and today,.........so, guess what I did ? :D
In the middle of the night....i.e just now.
debe
Joined Sep 21, 2010
1,419
Guess they will have to call you to fix the mysterious problem!!! Just curious how did the Tacho work & was it close to acurate?
R!f@@
Joined Apr 2, 2009
10,011
About the tacho, it's funny...
There are no holes in the meter to adjust anything, but when I throttle the engine RPM responds accordingly. I mean not over scale or anything. I guess the meter is an Alternator tacho type, right ?
Abt last night. !!!
It's not a problem to fix, it's big. Wait till they try to take off. :D
R!f@@
Joined Apr 2, 2009
10,011
Yup ! at idle that's what I get.
{ed}
I took back what is mine just in case.
But tonight they paid. So All's well tht end's well ..Eh!
