Oh believe me I have the PDFs, and there are many more in Google searches on the subject. And none of them are being done like what you're trying. And to compare the noise of a common old school pick and place to one using a working tubular linear motor is like comparing apples to orangutans. Not even oranges.Hahahaha. I knew I shouldn't have taken the bait.
Ordered. Thank you.Na I did't leave I just been busy hooking up stuff i know nothing about after 40 years funny thing is it works LOL.
You are using wrong bit to make pcb you milled all the copper track out
https://www.amazon.com/Autek-Titani...=1532567482&sr=8-14&keywords=pcb+milling+bits
HAA! Oh, how the tables have turned....Ben Varvil
You should visit this thread
EDM - Electrical discharge machine
and harass Shortbus about spending hours and hours and hours and hours drilling holes with sparks.
False.And I'm still waiting to say, "I told you so!
Ok, back to work...So I'll say it now, "told you so".
That is the first thing I've seen that matches the way people are doing this, in both manufactured LMs and in patents and thesis.Or even just play with the code till it moves all the way right and figure out how long it takes from that to get the outcome you want.
So far he doesn't really want to do any type of research, or even think about any thing that doesn't match him and those that tell him he's on the right track. Sad as that may sound.If you run out of ideas, research coil guns, you are just shooting the barrel.
Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
- Any kind of over-unity devices and systems
- Devices designed to electrocute or shock another person
- LEDs to mains
- Any kind of jammers (ie - Phone jammers)
- Rail guns and high-energy projectile devices
- Transformer-less power supplies
Are you using permanent magnets to bias them?The hall sensors are proving to be unreliable.
YesAre you using permanent magnets to bias them?
