Why isn't this Op Amp saturated ?
Status
Not open for further replies.
35,291
You cannot have both.
It is like a nuclear reactor. You can have criticality less than 1 (C), equal to 1 (B), or greater than 1 (A).
Xenon02
Joined Feb 24, 2021
504
But I have seen some examples where there are used two feedbacks at the same time.
So I was curious how people are solving it. Because I know how it works with only positive or only negative. But if there is both? Is it like one of them is dominating or what? Or how does it work ?
35,291
He might be thinking of a differential input and differential output amplifier.
This is still negative feedback on both arms of the circuit.
Xenon02
Joined Feb 24, 2021
504
Ok this is wierd I didn't know there would be two outputs.
But still I didn't get the answear to my question :
The link didn't consist the circuit with two feedbacks and 1 output.
Because this one has one output.
Like here 2 feedbacks 1 output.
Xenon02
Joined Feb 24, 2021
504
But to be sure.
Why they are giving this circuit to calculate when there is no practical use?
By the way is it even possible to calculate it ? I'm just curious because maybe I will meet something like this and I will be "bamboozled"
38,932
I think basically the circuit operates in the linear region if the negative feedback is greater than the positive feedback, and latches (bistable) if the positive feedback is greater than the negative feedback.
Xenon02
Joined Feb 24, 2021
504
You are probably right.
How to calculate which feedback is greater ? Is there a tutorial with 2 feedbacks ?
You can write an equation for it, but it might not have a single stable solution.
Yea but I don't know how to calculate it. I just need a tutorial. Video or a circuit with 2 feedbacks on the weebsite step by step.
Xenon02
Joined Feb 24, 2021
504
I know there was a method method of nodal potentials but I haven't mastered it yet.
I just don't know how this circuit even works. Where to current flow.
I've found something like this :
https://electronics.stackexchange.c...dback-of-opamps-so-different-how-to-analyse-a
The guys is trying to solve it by saying it is negative feedback when in lim Av -> infinite (Vout/Vin) is infinite then it is positive feedback. But I don't know if this is also the same here.
DickCappels
Joined Aug 21, 2008
10,661
You seem to be asking a lot of questions to which you could easily find answer on your own, rather than engaging in long, drawn-out discussions those who would like to help you. This is not only true of this thread, but others on this site.
For your op-amp questions, I have some suggestions.
On this site: https://www.allaboutcircuits.com/textbook/semiconductors/
Burr-Brown Operational Amplifier Handbook
Handbook Of Operational Amplifier Active RC Networks
If you have difficulty with any particular terms or concepts in these tomes you are welcome to ask for specific help on this site. Dragging individuals with good intentions into endless conversations are frowned upon.
Status
R General Electronics Chat 9
