Why is text from JSON overlapped on OLED?
  • Thread starter Deleted member 750607
  • Start date
Joined Dec 31, 1969
Its not because of the position of the cursor, its because I don't know how to separate Longitude from Latitude in my code.
http://api.open-notify.org/iss-now.json
...you can see in the pic that the numbers aren't clear because both Longitude and latitude are on top of each other
How do I separate them? my code is under this pic
Main file:
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <Adafruit_GrayOLED.h>
#include <gfxfont.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <SPI.h>
#include <Wire.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#include "USE_ESP8266.h"
#include <TimeLib.h>
char server [] = "api.open-notify.org";
void digitalClockDisplay();
void setup ()
display.begin(SSD1306_SWITCHCAPVCC, 0X3C);
display.clearDisplay ();
  Serial.begin(115200);
  if (!configureNetwork()) //start the network
    Serial.println("Failed to configure the network");
    while(1)
      delay(0); //halt; ESP8266 does not like infinity loop without a delay
int ret = client.connect(server, 80);
if (ret == 1)
  Serial.println("Connected");
  client.println("GET /iss-now.json HTTP/1.0"); //the http request
  client.print("Host: "); client.println(server);
  client.println("Connection: close");
  client.println();
else
  Serial.println("Connection failed, error was: ");
  Serial.print(ret, DEC);
  while(1)
    delay(0); //halt; esp8266 does not like infinite loop without a delay
char timestampMarker[] = "\"timestamp\":";
char posMarker[] = "\"iss_position\":";
void loop ()
  if (client.available())
    String id = client.readStringUntil('"');
    if (id.equals("timestamp")) //start of timestamp
      if (client.find(':')) //a ":" follows each identifier
      unsigned long timestamp = client.parseInt();
      setTime(timestamp);
      else
        Serial.println("failed to parse timestamp.");
    if (id.equals("iss_position")) //start of position data
       while(client.peek () != '}' && client.find('"'))
        String id = client.readStringUntil ('"');
        float val = client.parseFloat ();
        client.find ('"');
        Serial.print(id + ":"); Serial.println(val, 4);
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("longitude:");
display.display();
display.setCursor(0,10);
display.println(val);
display.display();
display.setCursor(0,40);
display.println("latitude:");
display.display();
display.setCursor(0,50);
display.display();
      else
        Serial.print("Failed to parse position data.");
if (!client.connected())
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    while(1)
    delay (0); //halt, esp8266 does not like loop w/o delay
String padDigits(int digit)
  String str = String("0") + digit; //put a zero in front of digit
  return str.substring(str.length() - 2);
void digitalClockDisplay ()
  String datestr = String(year()) + "-" + padDigits(month()) +
                   "-" + padDigits(day());
  String timestr = String(hour()) + ":" + padDigits(minute()) +
                   ":" + padDigits(second());
  Serial.println(datestr + " " + timestr);
Header file:
#include <SPI.h>
#include <ESP8266WiFi.h>
const char ssid[] = "Home25";
const char password[] = "6033216098";
WiFiClient client;
bool configureNetwork()
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay (1000);
    Serial.print("Waiting for connection to "); Serial.println(ssid);
    return true;
Irving
Joined Jan 30, 2016
5,195
The structure of your while loop is wrong. You're displaying the same information each time through the loop. You should also be using the JSON library to access the content rather than parsing it by hand.
You need a couple of If statements or a switch()/case block to display the values at the right cursor location e.g. Something like...
C-like:
  while(client.peek () != '}' && client.find('"')) {
      client.find ('"');
      If(id == "longitude"){
         display.print("longitude:");
         display.print(val);
      if(id == "latitude"){
         display.print("latitude:");
         display.print(val);
  }//end while
  display.display();
other coding improvements:
Don't use println() use print() if you're setting cursor yourself. Only call display.display() once after you've printed everything. You only need to call setTextSize() and setTextColor() once before the start of the loop
Joined Dec 31, 1969
C-like:
      client.find ('"');
         display.print(val);
         display.print(val);
  }//end while
  display.display();
I am trying this out, but im not Sure im doing it right. Latitude not showing up...but a good thing happened, longitude is isolated now.
Joined Dec 31, 1969
C-like:
      client.find ('"');
         display.print(val);
         display.print(val);
  }//end while
  display.display();
is this meant to go in with the rest of my code? im assuming its not meant to stand by itself...?
Irving
Joined Jan 30, 2016
5,195
yes, its a snippet of code around the while loop... it replaces lines 83 to 116 approx in your original code. If you're still missing 'longitude', check that the 'id' retrieved from the JSON is the same spelling & length as the string its being compared with in line 10 of my code snippet...
Joined Dec 31, 1969
Works perfect now, THANKS!!!! also starting to learn a few things from what you told me.
