panic mode
- Joined Oct 10, 2011
- 5,113
Can you elaborate on this? What would that help with? I guess that would turn it into reverse polarity protection but regulator output would still produce same 5V. Teensy supply can be 3.6-5.5V.the 1N5819 diode should go BEFORE the regulator, it does nothing but reduce your Vdd, as placed.
Proposal to add diode there was meant to prevent possible issues that Teensy seem to be affected by when power is applied both by 5V regulator and by USB cable. there is plenty of discussions on this, suggesting alternatives like cutting/soldering pcb jumper on the Teensy, or using switch etc. this way one does not have to modify USB cable or Teensy itself.
