... read about the water line freezing, but would not have thought that insulation was the problem. Could there be a crack or cold air leak in the plastic door part, causing the problem?
... Edit ... the water line is at the back, right. The problem would have to be cold air in that location, I guess.
... Edit again ... There is usually a defrost drain line (usually a tube) going from the back of the freezer to a pan at the bottom, near the compressor, where the water can evaporate. What can happen sometimes is that mold, dirt, or something can cause that drain line to get stopped up, with resulting problems. So, just take a look. on the back of the unit and see if there is a short length of tubing exposed on the back, maybe halfway up or so. That tube would be the drain line. There should be some way to check and see if that drain tube is clear from the freezer compartment to the drain pan at the bottom.
