which type of dc to dc converter to use to convert 5V, 80mA input to 3V 300mA output?
ashokraj
Joined Feb 1, 2018
151
I am working on a solar panel whose output maximum specifications are 6V, 100mA ( nearly 0.6watt). Practically these values came to 5v, 80mA when tested in afternoon sun. I want to run a motor whose operating voltage is (3~12V), no load current is 180mA. I would like to know what are the ready to available module I can use to make this possible. I have little knowledge of DC to DC converters. In this example do I have to use Step down converter or buck boost converter ? Usually I am with an impression that power can neither be created no destroyed so in the buck converter the voltage reduces and current amplifies so I can use it. Am i right ?
There are different types of buck converters available I would like to know how to select the right one for my application?
For example please see the below link :
1. LM2596 in this they mentioned output current as 2A. does it mean it supplies 2A at any output irrespective of input and output voltage ?
2. AMS1117 in this they mentioned ouput current as 800mA . does it mean it supplies 800mA in definetely !!?
As I need more current than the input current I have eliminated the option of boost converter which increases the voltage and decreases current at the input.
will be waiting for your answers. thanks in advace.
Ya’akov
Joined Jan 27, 2019
10,226
A magical one?
You have 5V at 80mA which is .4W you want 3V at 300mA which is .9W
Where will the extra half Watt come from?
All conversions from one voltage to another have to choose between current and voltage. You have a certain amount of power, which is expressed in Watts, and you can use that budget, minus the unavoidable conversion losses, to shuffle the voltage and current outputs but you can never get more than you put in and in fact always have to get somewhat less out.
Ya’akov
Joined Jan 27, 2019
10,226
One more thing, you can use time as well. If you charge a battery or capacitor you can get higher currents than the input but only for the amount of time you charge minus losses. So if you charged, say, a supercap at some rate for some given time then you could have your higher current for some time after charging and do it again.
But you can't get more out than you put in, ever.
bertus
Joined Apr 5, 2008
22,911
You can never get more on the output than you put in.
You will need about 200 mA at the 5 V input at a high efficiency of 90%
Bertus
ashokraj
Joined Feb 1, 2018
151
hi, when you say a super capacitor can I use 1000uF electrolytic capacitor?
Ya’akov
Joined Jan 27, 2019
10,226
It wouldn’t run a motor for more than a fractional second. A super cap is something different.
A super cap would be more like 5F, or more. You can search for super capacitors online, lots of information. They are a bit like super fast charging batteries.
ashokraj
Joined Feb 1, 2018
151
Dick, he wants more power out than he is putting in.
I will add another solar panel in series, so the input power can be 10V, 80mA = 0.8 watt, in this situation if I keep 3.3V at the output I could get a 240mA!!!
In this scenario which module is more recommended to use , AMS1117 or LM2596 mentioned in the post, any method/ procedure which I can find out.
Ya’akov
Joined Jan 27, 2019
10,226
The LM2596 buck converter will be more efficient than the LDO but it requires more external components.
sghioto
Joined Dec 31, 2017
8,634
AMS1117 in this they mentioned output current as 800mA . does it mean it supplies 800mA in definetely !!?
This means the LDO can handle up to 800ma, it does not supply current. If you connect two panels in series and use the LDO the current output is only what the solar panels can deliver safely which is still only 80ma.
What you really need is a 5 volt 5 watt panel, then you can drive the motor directly.
Ya’akov
Joined Jan 27, 2019
10,226
EDIT: Ignore this response, it's the result of divided attention and it completely irrelevant.
My bad for not noticing the deficit in the LDO specs. He can't use the LM1117 because he still needs too much current. It looks like a 7805 might be a good choice, for some values of "good choice".
Ya’akov
Joined Jan 27, 2019
10,226
Lost me here. What difference would a 7805 make if the panels can only deliver 80 ma.
I am doing too many things at once. To untangle the confused state I put myself into to make that post would require years of therapy. Let's just say I entered an alternate reality where you said something different than you actually did and I responded to a third thing when I got the thing you didn't say even wronger.
BobaMosfet
Joined Jul 1, 2009
2,211
@ashokraj You cannot get higher current AND higher voltage using anything. They work reciprocally- In order to raise one, you must lower the other.
Here is an example using the ubiquitous MC34063A
The RED value above, shows you that it will need 1.0624 Amps input to get both the voltage and the current raise to get you 12V @ 180mA from 5V.
That higher voltage and current has to come in the form of input current and/or voltage. Which you don't have.
