Circuit Issue Help - Buck Converter with Type III Analog Voltage-Mode Controller
Rborres07
Joined May 4, 2024
8
Hello there! I am working on a buck converter (Input: 24 V, Output: 10 V) with gate driver circuit and type III analog voltage-mode controller. I am facing the issue wherein when I'm inputting around 12 V it outputs 9 V but then the current is also high (around 1.4 A). The duty is around 90% already at that point and when I increase the voltage further it fluctuates at around 4-6 V output voltage. The specifications for the comparator is TL5001 with switching frequency chosen as 30k Hz. I have also attached the circuit diagram below (please also comment improvements for the circuit diagram). It also utilizes a NAND Gate (C47107B) and TLP250H for the gate driver circuit. I am not sure where the issue is but I assume it's regarding the comparator and controller part. If you have any thoughts on what the problem might be please help me. Thank you very much.
LowQCab
Joined Nov 6, 2012
5,102
So why are You operating it by varying the Input-Voltage far below what it was designed for ?
This Circuit is "Buck only", not "Buck-Boost".
It requires an Input-Voltage that is a certain number of Volts in excess of
the expected Output-Voltage, at all times, to insure stability of operation.
Rborres07
Joined May 4, 2024
8
Even if I open the power supply at 24 V immediately, it outputs around 5 V with a varying duty cycle. I tried turning the Vcc source first then the Main Power Supply and the other way around but it still outputs an unstable 5V output voltage. I'm just wondering why it peaks at 12 V around 2 V above the required switching ON voltage for the MOSFET used.
LowQCab
Joined Nov 6, 2012
5,102
Please explain why You are using a special "Type-III" Voltage-Mode-Converter.
Not that I'm all that well versed in various Buck-Converter-Feedback schemes,
but I've never heard of a "Type-III" Buck-Converter,
and the Schematic rendering program that You are using
makes it impossible to decipher what's going on in this Circuit.
ronsimpson
Joined Oct 7, 2019
4,856
There are several things that I don't understand.
1. There is a 6V battery that appears to have the negative end not connected.
2. In all but one case where wires come together, I cannot tell if they connect or just pass over.
3. Put part numbers on the ICs and MOSFET.
4. I can't see how (IC on the left) gets powered.
Rborres07
Joined May 4, 2024
8
Th
Thank you for your reply.
1. The negative end is connected to the ground and shoulb be parallel to both the bypass capacitors. I'll fix the diagram for this.
2&3. I really appreciate the comments with regards to the circuit diagram. I'll be sure to fix it.
4. The IC on the left is powered by the "bootstrap circuit" which is composed of the diode, resistor, and capacitor on top.
You circled something on the comparator part which I do not understand. Would it be possible to clarify it?
Rborres07
Joined May 4, 2024
8
Type III basically just refers to the controller wherein I used 2 poles, 2 zeroes, and 1 integrator to adjust the controller GM and PM. This is what it would like in PLECS as well as the controller design from MATLAB.
Ian0
Joined Aug 7, 2020
13,310
Types I II and III refer to this application note from TI.
Type III is a voltage-mode converter, so it needs more complicated feedback.
