Where to find PWB pin/header with split head (push down to cut wire insulation)
Bernard
Joined Aug 7, 2008
5,784
The T28/C terminal seems to be wire size sensitive; .018" is slightly loose, .022", 1/4 W resistor, seems about right. The WW terminals require soldering.
dl324
Joined Mar 30, 2015
18,469
T68 won't cut through insulation:
The connector I mentioned in post #18 is for #28 stranded wire.
Specs for T28:
Fran3
Joined Mar 28, 2019
51
Great, the T28 looks like what I'm looking for.
FYI, I understand this "terminal" or "pin" or "Post" would not be the first choice for a stake header or as a reliable"push down" connector. We have a special application for which we are considering the part.
Thanks for the help everyone.
