Where to find PWB pin/header with split head (push down to cut wire insulation)
Fran3
Joined Mar 28, 2019
51
I'm not sure I described this correctly but in the past I have seen...
single pins or headers or connectors on printed circuit boards that had sort of a split top...
so you could push a wire (or wires) down into the split and make a connection.
I've Googled until my eyes have rolled back in my head and can't find them so I'm sure I don't have the proper description.
Can anyone help me out in my search for these things.
Thanks.
Fran3
Joined Mar 28, 2019
51
yes, the Insulation displacement connector is the idea...
But these were single "pins" that you could push into a hole on a PCB with the split part... insulation displacement part at the top... so it stuck up like a test point or single stake header...
This allowed you to push a wire (or wires) into the split part to make a connection.
Bernard
Joined Aug 7, 2008
5,784
I have some, but no history other than similar construction to some Amphenol crimp connectors formed from flat tin plated brass formed into U. A hole in tip & top with top having serrated edges forming a V slot .
Fran3
Joined Mar 28, 2019
51
Yes Bernard, your drawing is exactly what I'm looking for.
Does anybody recognize this pin and know where to buy them?
Bernard
Joined Aug 7, 2008
5,784
A pin that looks similar to post #18 is Vector Electronic Co. T68A, 5/8" long, T68, .8 " long, .025 sq. Wirewrap tail, .032" wide slot. Or T44 , .69 long with .021" slot.
