I need a U.FL to female header cable like the one shown in this picture
But I can't seem to find one anywhere on the internet. Any clue where one exists?
Are you saying I can't use this for Mclock transfer? I need to connect Mclock on an Amanero to a fifo board, the Amanero uses header pins and the fifo has only a U.FL connection for Mclock slave output.Seems like complete nonsense to me. If one end requires UFL and 50 ohm coax cable, what good will it do when you make a huge impedance discontinuity and connect it to a 100mil header? The result at the header will most likely not be useful signal but rather garbage.
But UFLs that attach to pigtails don't exist. U.FL is a 2 wire connector right?but pigtails are readily available, which is what I thought you wanted. You can then attach whatever you want to the other end(s).
