What is this second thing?
AlbertHall
Joined Jun 4, 2014
12,654
This one has what looks like a clear LED and between this and the cable exit a smooth shiny rectangle which may or may not be a window. It looks black but could be an IR filter.
Tonyr1084
Joined Sep 24, 2015
9,744
Given that the plug has only two contacts, I don't think it's any sort of IR receiver. It doesn't seem to be anything more than an LED on a plug. For what purpose it may be - - - ?
AlbertHall
Joined Jun 4, 2014
12,654
I was particularly curious as it has no mounting hole or other means of attachment.
I measured across the pins with the meter on 'diode check' and it reads 1.06. I guess that's about right for an IR emitter.
Tonyr1084
Joined Sep 24, 2015
9,744
Is the black shiny thing magnetic?
Will a magnet stick to the BST?
It might be the means by which it mounts to something. OR perhaps if it's a magnet it might activate a Hall effect transistor or a reed switch.
Tonyr1084
Joined Sep 24, 2015
9,744
Also, wondering if it's some sort of repeater. Perhaps the two wire connection provides power to the device. An IR signal is received then by means of amplification it repeats the IR signal to something that may be otherwise beyond the capability of some remote.
I had an idea several years ago to take a flashlight with multiple LED's and replace the LED's with IR LED's. Then drive them from a TV remote. In a Motel where all the TV's are typically the same make and model, use that flash light to broadcast a bright beam turning the TV's on in the adjacent rooms across the parking lot. Imagine waking everybody up at 2:00 AM with the TV coming on and blasting. A cruel joke - I know. More of a "I wonder if it can be done" than something I'd actually want to do.
AnalogKid
Joined Aug 1, 2013
12,284
Based on what I own, it's an IR receiver. The one I have plugged into a VCR. The VCR could be in a home entertainment cabinet of the 80'8 - 90's, with the receiver outside the cabinet for better reception. Inside the device might be nothing more than a photo-transistor or photo-diode, plus transient protection.
ak
Tonyr1084
Joined Sep 24, 2015
9,744
Quite possible. But what's the LED for? Unless that's not an LED but rather, the IR Receiver.
28,454
It looks a WHOLE lot like the IR remote control pickup for one of the very small cable TV/digital TV converters that I have connected for my friends. It is probably a photo-diode.
AlbertHall
Joined Jun 4, 2014
12,654
ak
Across the two connections it reads like a diode, forward voltage 1.09V. Is that how a photo-diode would read?
Tonyr1084
Joined Sep 24, 2015
9,744
Following this thread out of curiosity. Based on AnalogKid's link I opened a random data sheet. Found this:
Vf appears to be 1.3V @ 80mA. So your question about typical PD Vf would appear to be reasonably correct.
Externet
Joined Nov 29, 2005
2,678
Perhaps helps a bit:
Decades into electronics, learned to recognize some clear lensed LEDs just by appearance.
If the die is blackish; it is an IR emitter. If lens is tinted dark, is an IR receiver. If clear lens but not blackish die, it is a visible light LED. If yellowish shrouded, is white emitter. Just observe its guts. Triple die IR emitter :
Plain color :
