What is the zero of this TF
fadelo
Joined Apr 12, 2011
22
Hello
I'm confused when working with transfere function in order to know poles and zeroz the for functions having (K) = gain in the numerator for examble
g(s)H(s)=k/s(s+4)(s+2)
here the poles are s=-4 and s=-2 ok what is the zero??
what about this examble also:
ks/(s+6)(s+2)
regards
panic mode
Joined Oct 10, 2011
5,168
your transfer function can be represented as
k*(A1*A2*A3*....) / (B1*B2*B3*...)
where A are zeroes and B are poles.
it should be obvious that whan any of A is zero, transfer function is zero.
when any of B is zero we get division by zero which is a pole.
each of A and B terms has general form
Ai=s+ci
or
Bj=s+cj
in case of
H(s)=ks/ (s+6)(s+2)
there is only one zero: A1=s
but there are two poles
B1=s+6 and B2=s+2)
since we are intersted in cases where A and B are zero, solutions are
A1: s=0
B1: s=-6
B2: s=-2
when you plot Bode diagram, you will use those values of s as corner frequencies.
in case of H(s)=k/s(s+4)(s+2)
there is no zeroes because numerator does not have any s-terms
we only have three poles:
B1=s
B2=s+6
B3=s+2
they are zero values when s=0, s=-2 ans s=-6
