What is the proper wiring for connecting ESP8266 to Arduino UNO
  • Thread starter Deleted member 750607
  • Start date
Joined Dec 31, 1969
the purpose of the circuit is to track the International Space Station and display the coordinates in the serial monitor
I know rx and tx go to corresponding arduino pins, and 3v3/GND are straight forward...but there are also RST, IO0, EN, and IO2 pins...there are many schematics online but im not sure what's right for my project
(also, my sketch is getting "error compiling for Arduino UNO board" message, but I thought maybe that was due to improper wiring?)
is it ok to run the esp8266 on Arduino UNO's 3.3v pin? my esp8266 is getting warm, if not hot
thx in advance, you guys are awesome!
djsfantasi
Joined Apr 11, 2010
9,237
First, the error you receive has nothing to do with the wiring and everything to do with the sketch.
I recommend you either attach the sketch to a post (you may have to temporarily rename it to a .txt file) or include the sketch in the post between CODE tags.
Joined Dec 31, 1969
I got this example code from a book...also can you help with the wiring too and not just the code?:
#include "USE_ESP8266.h"
#include <TimeLib.h>
char server [] = "api.open-notify.org";
int digitalClockDisplay();
void setup ()
  Serial.begin(9600);
  if (!configureNetwork()) //start the network
    Serial.println("Failed to condigure the network");
    while(1)
      delay(0); //halt; ESP8266 does not like infinity loop without a delay
int ret = client.connect(server, 80);
if (ret == 1)
  Serial.println("Connected");
  client.println("GET /iss-now.json HTTP/1.0"); //the http request
  client.print("Host: "); client.println(server);
  client.println("Connection: close");
  client.println();
else
  Serial.println("Connection failed, error was: ");
  Serial.print(ret, DEC);
  while(1)
    delay(0); //halt; esp8266 does not like infinite loop without a delay
char timestampMarker[] = "\"timestamp\":";
char posMarker[] = "\"iss_position\":";
void loop ()
  if (client.available())
    String id = client.readStringUntil('"');
    if (id.equals("timestamp")) //start of timestamp
      if (client.find(':')) //a ":" follows each identifier
      unsigned long timestamp = client.parseInt();
      setTime(timestamp);
      else
        Serial.println("failed to parse timestamp.");
    if (id.equals("iss_position")) //start of position data
       while(client.peek () != '}' && client.find('"'))
        String id = client.readStringUntil ('"');
        float val = client.parseFloat ();
        client.find ('"');
        Serial.print(id + ":"); Serial.println(val, 4);
      else
        Serial.print("Failed to parse position data.");
if (!client.connected())
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    while(1)
    delay (0); //halt, esp8266 does not like loop w/o delay
String padDigits(int digit)
  String str = String("0") + digit; //put a zero in front of digit
  return str.substring(str.length() - 2);
THEN, HERE IS MY HEADER FILE from the exemple code:
Code:
#include <SPI.h>
#include <WiFiNINA.h>
const char ssid[] = "Home25";
const char password[] = "6033216098";
WiFiClient client;
bool configureNetwork()
  int status = WL_IDLE_STATUS; //wifi status
  if (WiFi.status() == WL_NO_MODULE)
    Serial.println("Couldn't find WiFi hardware.");
    return false;
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION)
    Serial.println("Please upgrade your WiFi firmware");
  while (status != WL_CONNECTED)
    Serial.print("Attempting Wifi connection to ");
    status = WiFi.begin("Home25","6033216098");
    delay (1000);
  return true;
Joined Dec 31, 1969
void setup ()
  Serial.begin(9600);
    while(1)
if (ret == 1)
  client.println();
else
  while(1)
void loop ()
      setTime(timestamp);
      else
        client.find ('"');
      else
    Serial.println();
    client.stop();
    while(1)
Code:
#include <SPI.h>
WiFiClient client;
    return false;
    delay (1000);
  return true;
EDIT:
its not warm anymore, I had the wrong pin connected
Joined Dec 31, 1969
I fixed a few things I noticed were wrong in the header file, and now this is the error message
"pyserial or esptool directories not found next to this upload.py tool.
An error occurred while uploading the sketch"
Joined Dec 31, 1969
trying to use example code from a book, Arduino UNO and esp8266 to track the international space station and display longitude and latitude on serial monitor
but don't understand this error message:
main code:
void digitalClockDisplay();
void setup ()
  Serial.begin(9600);
    Serial.println("Failed to configure the network");
    while(1)
if (ret == 1)
  client.println();
else
  while(1)
void loop ()
      setTime(timestamp);
      else
        client.find ('"');
      else
    Serial.println();
    client.stop();
    while(1)
void digitalClockDisplay ()
  String datestr = String(year()) + "-" + padDigits(month()) +
                   "-" + padDigits(day());
  String timestr = String(hour()) + ":" + padDigits(minute()) +
                   ":" + padDigits(second());
  Serial.println(datestr + " " + timestr);
header file:
#include <SPI.h>
#include <ESP8266WiFi.h>
WiFiClient client;
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay (1000);
    Serial.print("Waiting for connection to "); Serial.println(ssid);
    return true;
Ya’akov
Joined Jan 27, 2019
10,226
That's a MacOS problem with Bug Sur and Python. The solution is to edit:
Code:
~/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/pyserial/serial/tools/list_ports_osx.py
You need to comment out two line, they should be 20 and 30 and add these just under:
Code:
  iokit = ctypes.cdll.LoadLibrary(‘/System/Library/Frameworks/IOKit.framework/IOKit’)
   cf = ctypes.cdll.LoadLibrary(‘/System/Library/Frameworks/CoreFoundation.framework/CoreFoundation’)
The two lines will look the same with different details.
For now, any time you change ESP library versions and get this error, it is because these lines are wrong and need to be changed. This will fix it.
Joined Dec 31, 1969
Code:
Code:
so I add /* ... *\ ? also, which lines get this? I don't know how to do this
Ya’akov
Joined Jan 27, 2019
10,226
so I add /* ... *\ ? also, which lines get this? I don't recognize the ones you sent
Locate the file ~/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/pyserial/serial/tools/list_ports_osx.py
Find the two lines (lines 29,30) that look like the replacements. Use # in front of each to comment them, then replace them with the new ones just below, as:
Code:
#iokit = ctypes.cdll.LoadLibrary(ctypes.util.find_library('IOKit'))
#cf = ctypes.cdll.LoadLibrary(ctypes.util.find_library('CoreFoundation'))
iokit = ctypes.cdll.LoadLibrary('/System/Library/Frameworks/IOKit.framework/IOKit')
cf = ctypes.cdll.LoadLibrary('/System/Library/Frameworks/CoreFoundation.framework/CoreFoundation')
Joined Dec 31, 1969
Code:
ok, one more thing, where is that file located?
Ya’akov
Joined Jan 27, 2019
10,226
~/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/pyserial/serial/tools/list_ports_osx.py is the full path to the file. The ~ is your home directory. So, /Users/<home> in front of that, but ~ is auto expanded into your directory.
Joined Dec 31, 1969
I don't see it when I search in my "finder"
Joined Dec 31, 1969
Is the file somewhere on my Mac already? Where?
Joined Dec 31, 1969
does it start like this? :
Arduino build test log started on Mon May 1 14:19:22 JST 2017
sketches=examples/Gyro/Gyro.ino examples/Interrupt/Interrupt.ino
boards= arduino:avr:uno Intel:arc32:arduino_101
## sketch=examples/Gyro/Gyro.ino
/Applications/Arduino-1.8.2.app/Contents/MacOS/Arduino --board arduino:avr:uno --verbose --verify examples/Gyro/Gyro.ino
Loading configuration...
Initializing packages...
Could not find boards.txt in /Users/johndoe/Documents/Arduino/hardware/Arduino_STM32/examples. Is it pre-1.5?
Preparing boards...
Verifying...
Ya’akov
Joined Jan 27, 2019
10,226
I'm sorry. I have told you twice now. This:
is the path to the file. That's where it is. It's in that directory. The last part: list_ports_osx.py is the name of the file, the rest is the path to the folder it is in.
It is in your home directory;
in the Library folder;
In the Arduino15 folder in the Library folder;
in the packages folder in the Arduino15 folder in the Library folder;
in esp8266 folder in the packages in the Arduino15 folder in the Library folder;
in the hardware folder in the esp8266 folder in the packages in the Arduino15 folder in the Library folder;
in the esp8266 folder in the hardware folder in the esp8266 folder in the packages in the Arduino15 folder in the Library folder;
in the 2.7.3 folder n the esp8266 folder in the hardware folder in the esp8266 folder in the packages in the Arduino15 folder in the Library folder;
in the tools folder in the 2.7.3 folder n the esp8266 folder in the hardware folder in the esp8266 folder in the packages in the Arduino15 folder in the Library folder
Joined Dec 31, 1969
sorry but one more question...is this file definitely already on my Mac or will I need to download it?
