What is the output of this VCO?
MightyBEard7
Joined Sep 22, 2020
5
I am using ROS-43-119+ from Mini-circuits. I need a VCO that can generate a 40MHz frequency.
ROS-43-119+ can generate my required frequency by controlling the tuning voltage.
I need sinewave output from the VCO. There is no mention of the output type in the datasheet.
So what is the out type of this VCO?
MightyBEard7
Joined Sep 22, 2020
5
@AlbertHall I will be using that VCO to generate a 40MHz signal. The tuning voltage of this VCO will be controlled from ADF401 PLL to generate 40MHz. The input reference signal will be a 10MHz sine wave signal.
bertus
Joined Apr 5, 2008
23,038
Did you see the min and max frequencies in the pictures I posted?
The ADF4106 will work from 0.5 to 6 GHz.
40 MHZ is 0.04 GHZ, so out of range.
Bertus
