How Should a Pull-Up Resistor Be Selected for an Open-Drain Output?
cedricuk
Joined Sep 7, 2026
32
I'm trying to understand how to choose a pull-up resistor for an open-drain digital output.
I understand that a lower resistance allows the signal to rise more quickly, but it also increases the current when the output pulls low. A higher resistance reduces current but can make the rising edge slower.
How do you normally select a suitable resistance when the supply voltage, input capacitance and required switching speed are known? Is it best to calculate the RC rise time first and then check the sink-current limit, or are there other important factors to consider?
I'd appreciate an explanation of the calculations and trade-offs involved.
Ian0
Joined Aug 7, 2020
13,312
Yes. That's the main criterion.
If your answer is so low that it exceeds the output current limit of the open-drain, then you really need a push-pull output.
And if your answers in in the Megohms, then it might get compromised by interference pickup.
The value of 1k belongs in 74series TTL days, and 4.7k for 74LS.
35,299
RC time-constant and load requirements are two different specifications.
I would consider load requirements first. Open collector and open drain outputs are designed to sink current.
The purpose of the pull-up resistor is to source current to the load. You need to know the maximum input current and the HI-level threshold.
For example, suppose that you are driving 5 V logic and need the threshold to exceed 4.5 V with an input current of 1 mA, then the value of the pull-up resistor is (5 - 4.5 V) / 1 mA = 500 Ω or lower. Choose 470 Ω.
If the input current is 100 μA, then the pull-up resistor is (0.5 V / 0.1 mA) = 5000 Ω or lower.
Next, you can consider switching requirements, which means that you need to know the input capacitance and your switching limits. Unless you have some very stringent switching requirements, TLL and CMOS circuits can usually operate well above 10 MHz without having to be concerned with switching times.
28,550
Selecting component values requires knowing the voltage and current in a circuit, and, usually, understanding wht the circuit does. So far we do not have enough information to make even a fair guess.
