Jon Chandler
- Joined Jun 12, 2008
- 1,621
Here's a picture of a general-purpose circuit board I designed for PIC18F-series chips. On the left edge near the top are solder jumpers for I2C pull-up resistors, as well as a pull-up and solder jumper for a reset line. The 6-pin connector is an IC2 or general purpose I/O connector. In addition to SDA and SCL pins plus 2 additional port pins. I followed the pinout of Microchip's ICSP connector, with +5 on pin 2 and ground on pin 3 – I have found this arrangement pretty tolerable of those "Oh crap" moments when you install the connector the wrong way around.
