What caused AC harmonics and why differential amplifier can't eliminate them?
Status
Not open for further replies.
Secan
Joined Sep 20, 2024
205
The following is from an AC Adaptor connected to an EEG amplifier. Even though the 60Hz was notched filter and differential amplifier used, how much the harmonics were not substracted? And what exactly created the 60hz harmonics? The vertical lines are multiples of it like 120Hz, 180Hz, etc. How are they caused exactly?
38,802
The ripple frequency from the adapter could be the rectified 60Hz, which has a fundamental of 120Hz plus harmonics of that.
That would be difficult to filter from the signal.
Likely better to reduce the ripple noise from the AC adapter output with perhaps an LC low-pass filter along with a common-mode choke.
Secan
Joined Sep 20, 2024
205
The following is the exact AC adaptor. Why is it difficult for differential amplifier to remove the noise when it is just one vertical line spaced every 60Hz apart? It is the simplest common mode that differential amplifier should easily deduct. It's not even white noise. Just the vertical lines.
Think about where the harmonics are coming from. Is it the signal inputs or the power bus?
https://www.globtek.com/datasheets/GTM21097_SERIES-50W.pdf
Lots of designs use batteries to eliminate PS generated power bus noise.
Show us the schematic.
schmitt trigger
Joined Jul 12, 2010
2,226
EDIT;
Differential amplifier’s purpose is to reject common-mode signals while simultaneously amplifying signals that appear differentially across its terminals. Which I suspect is what is happening. You have got a differential signal.
But…You are not showing nor explaining how you connected the AC adapter to the EGG amplifier. Without that information we would be only guessing what exactly is going on.
Secan
Joined Sep 20, 2024
205
This is the schematic. But is it not the 60Hz and harmonics are common mode. Why arent they easily removed by the differential amplifier since they are just vertical lines that appear at all channels?
What happens when it's battery powered?
Do you really understand what those vertical line mean? Do you have any real understanding of electronics and signal processing?
Secan
Joined Sep 20, 2024
205
When it is battery powered. There were no vertical lines. I know those vertical lines mean harmonics, but why aren't they cancelled? and what formed them? I once took a half course in electronics but moved to biology halfway. and so my idea of signal processing is only the Zilog Z80 microprocessor.
Alec_t
Joined Sep 17, 2013
15,156
1) What is the amplifier connected to via its USB port?
2) Does the amplifier have any floating inputs?
3) At which point in the circuit are you detecting the 60Hz and harmonics?
4) What grounding and screening arrangements does the adapter have?
Secan
Joined Sep 20, 2024
205
1.g.USBamp
2. How do you know if it has floating input?
3. The 60Hz harmonics is from the EEG recording
4. See adaptor in original message..it has no grounding in the plug
Ian0
Joined Aug 7, 2020
13,278
You have 60Hz harmonics not 120Hz harmonics, the biggest being the 3rd harmonic at 180Hz. That eliminates any possibility of its coming from rectified AC.
Secan
Joined Sep 20, 2024
205
Why cant the 60Hz harmonics come from rectified AC? Where does the harmonics come from then? Note I used Matlab FFT to see them from raw EEG waveforms.
Ian0
Joined Aug 7, 2020
13,278
Because rectified unsmoothed AC is 120Hz.
As you have 60Hz harmonics, they must originate from the mains, not your power supply.
Secan
Joined Sep 20, 2024
205
Ok if they originate in the main. Still why aren't the harmonics canceled by the differential amplifier since both channel 1 and channel 2 have the same common mode harmonics?
schmitt trigger
Joined Jul 12, 2010
2,226
A diff amplifier is not a comb filter. It only amplifies a signal which appears differentially across its input terminals. Which somehow you must have but don’t want to share the details.
The “schematic” that you posted is only a block diagram. You don’t show where or to what were those inputs connected to during the data capture, yet you become upset at members because they aren’t mind readers.
I am done dealing with arrogant members and putting you on my ignore list. Do the same for me.
Ian0
Joined Aug 7, 2020
13,278
Either the common mode rejection isn't as good as it should be, or the signal is differential.
Different impedences at the two inputs would be enough to cause different amounts of pickup at the two inputs, then you have a differential signal.
Why would you think that precisely the same signal would be picked up on different parts of the head?
Secan
Joined Sep 20, 2024
205
Well. I am surprised by this reply. This is true for all bioamplifiers. If you use AC adaptor, you get harmonics regardless if the inputs are floating or connected. I was asking why the harmonics still appear when they are common mode and all differential amplifiers should filter them. The harmonics show up at FFT.
Secan
Joined Sep 20, 2024
205
Note even if the electrodes are floating or connected to head (see above message too). Same 60Hz harmonics. I tried these in 3 brands of EEG like Brainmaster, CWE BMA-2000 and the gtec g.USBamp. Same results if all electrodes are floating or connected, the 60Hz harmonics still show up even when channel 1 is deducted to channel 2. The AC 60Hz harmonics should be present in all channels without passing thru inputs but via the chip or ic power supply, isn't it?
But wait, why isn't the power supply voltage also substracted since they are also common mode.. perhaps the clue is here.
Alec_t
Joined Sep 17, 2013
15,156
If the mains input to the adapter has no grounding and the adapter input and output wiring is unscreened then there could be considerable mains supply noise in the vicinity of the amplifier. Since the amplifier input impedance is specified as >100 MegOhm the amplifier will be very sensitive to radiated mains interference if its inputs are not coupled to a much lower impedance. Even head impedance may not be low enough to reduce input noise to a non-noticeable level.
Different lengths and/or positioning of the input electrode wires will prevent complete interference cancellation by a differential amplifier.
Secan
Joined Sep 20, 2024
205
Oh. The adaptor has grounding but in my country, we never use any grounding so I just plugged the 2 pins to 220V A.C. in the outlet. See related thread about groundless A.C. Continous Fault Current passing through Earth ground | All About Circuits
Why is that if the amplifier input impedance is specified as >100 MegOhm the amplifier will be very sensitive to radiated mains interference if its inputs are not coupled to a much lower impedance?? Please elaborate. Thank you.
Status
