Wattage in voltage devider
Chillum
Joined Nov 13, 2014
546
You can use trimmer pot since you are building just 5V regulator if you wanted more voltage i'd lose pot.
I thought I wanted just 5V, but now you turned me on to the *world of many voltages" :) might come in handy to change to a value closer to 10V. most LEDs at yebo are 10V, so there's atleast one reason to go for the pot solution! :)
ISB123
Joined May 21, 2014
1,236
What kind of led works on 10V? Are you are powering led strips?
33,239
That will not do for TTL logic circuitry.
You need the +5 volts to be as exact as you can make it.
TTL is more sensitive to overvoltage. 5.1 is within range but too close to the TTL range of 4.75V - 5.25V supply.
Further the 5V provides the reference level for the logic pulses.
By contrast the CMOS voltage range is +3V to +15V
This is a good opportunity to practise your series and parallel skils to get your resistors closer in combination, though most practical people would use a trimpot and set the final value to give correct output with a voltmeter.
Why do people keep saying that the CMOS voltage range is +3V to +15V?
The allowable voltage range is highly dependent on the CMOS family. Today, very few families can tolerate 15V and many are designed to work at 2.5V or lower. For example, the 74HC family, which is hardly new, has a max Vcc of 7V and is spec'ed at Vcc levels of 2V, 4.5V and 6V.
Making blanket statements about CMOS being able to run up to +15V is just encouraging people to let the magic smoke out of modern logic parts.
BobTPH
Joined Jun 5, 2013
11,660
Cellphone (and other) chargers are not usually suitable without modification as they are not true DC.
Have you tried downloading my attachment and viewing it full size? The underlying pic is quite large and easier to see that way.
This is nonsense. I use cellphone chargers that I buy for $1 at flea markets for microprocessor projects. Every one of they put out rock solid 5V DC. I was surprised at how good they looked on a scope.
Bob
Chillum
Joined Nov 13, 2014
546
Bob
Phew! I didn't buy the chargers for nothing! I was very worried there for a moment! Thx Bob!
Chillum
Joined Nov 13, 2014
546
Bob
Bob, if you say microprocessor projects, how much current would I need for standard messing about with digital electronics, or are there no easy answer?
BobTPH
Joined Jun 5, 2013
11,660
There is no easy answer, but 1A should last you a long time.
The things that you are likely to use that would consume more than that are things like motors or high power LEDs.
I should correct that, microprocessor -> microcontroller.
The microcontrollers themselves use only a few milliamps. The highest powered one I use uses 60mA at top speed.
Bob
Chillum
Joined Nov 13, 2014
546
Bob
And with this 1A limit, how easy is it to add another psu, like use one psu for 5v and a 12V psu for the rest, ok so it's a project that requires two wall sockets, but hey, I'm a student, not a fabricator
ISB123
Joined May 21, 2014
1,236
Current usage of microcontroller is very small,its like 60 mA at 16mhz for atmega ones and its going to depend on how much stuff you have hooked up on microcontroller.
If you are controlling high power motors they need a separate supply going into the driver IC.
ISB123
Joined May 21, 2014
1,236
Pin 2 of trimmer needs to be connected to ground.You will need a 2200uf capacitor before lm350.Protection diode should be placed above the regulator.
Chillum
Joined Nov 13, 2014
546
which diode? On hand I have (but I'm anyways making a trip to yebo, so I could just buy the correct one) 1n4148,1n4007, and 5* 1n5402 (the other 2 I have 10 of each)
Chillum
Joined Nov 13, 2014
546
studiot, I have 4* MJE3055T already, for the negative part, isn't swopping the polarity on the MJE3055T the same as using a MJE2955T, they're complementary transistors, just the one is npn (3055) and the 2955 is pnp, I'm sure I read something to that effect somewhere?
