I need to reduce automotive voltage down to CMOS level. My project is converting a garage door remote opener to an integral part of my motorcycle and powered from the motorcycle electrical system. I decided to build a simple voltage divider using resistors. I read that it is not good to use high resistance so I purchased 2 and 7 Ohm resistors.
(14 VDC * (2 / 9)) = 3.111 VDC.
The circuit will only be energized when I honk the horn so heat from the resistance should not be an issue. Am I on the right track or headed for a train wreck?
Ron
Ron
