Voltage booster running too hot
Dwubyd
Joined Nov 20, 2019
Hi, I am using a micro USB to charge a 2 cell lipo in a Bluetooth speaker project. I am using a voltage booster to convert the 5V input from the micro USB to 8.5V for the balance charging module. It is pulling 2.4 to 2.5 A, which is making the booster very hot. I am concerned that when I put it in the enclosure it will get even hotter, being in an enclosed space and will burn out. The booster is one of these: booster
I am looking for an easy way to reduce the charging current. Any ideas?
ericgibbs
Joined Jan 29, 2010
21,649
Hi Dw,
Welcome to AAC.
The Booster spec does state 2A max.
You could use a series power resistor or power diode/s to reduce the current.
This will of course increase the recharge time.
E
Features:
The smallest adjustable boost module can be easily installed in a variety of small equipment.
Wide input and output voltage, high conversion efficiency.
This module is a step-up module, the output voltage is larger than the input voltage.
Specification:
Quantity:5pcs
Maximum output current: 2A
Input voltage: 2V ~ 24V
Maximum output voltage: > 5V-28 v
Efficiency: > 93%
Size: 36 mm x 17 mm x 14 mm
Precautions
The input voltage should not exceed the maximum input voltage.
Peak current output current does not exceed 2A
Dwubyd
Joined Nov 20, 2019
I only know a little bit about circuits, but is seems to me that a series resistor would be simple, effective although an unrefined solution. I will give it a go. V = 5v, I = 2.5A, => R=2 ohm. So I will try adding in a 2 ohm resistor to drop current to 1.2A
