VHF/UHF tv antenna design
Janis59
Joined Aug 21, 2017
1,894
The only <complex> thing for the dongle may happen be curvy fingers installing the software. Then know the right witchcraft word = Zadiq.exe (never knew, is it willfully or not, but in russian it means "the little arse". Its just the zipped folder where all soft be installed are together and installs automatically for any SDR and even the HackRF-001 as this technology highest peak song.
MisterBill2
Joined Jan 23, 2018
28,224
Say WHAT?????????????
dovo
Joined Dec 12, 2019
72
Hi, i am a beginner in electronics, i want to design a VHF/UHF tv antenna in the frequency range of 40 - 800 mhz. What are the most reliable tv antenna design pages ?
As others have said, Log Periodic antenna is a preferred choice. The design of such an antenna is detailed in the LPDA link. A popular antenna for over the air TV homebrewers is the Gray-Hoverman. Construction is less critical and it has fewer pieces.
LPDA https://feng.stafpu.bu.edu.eg/Electrical Engineering/3111/crs-14248/Files/lect10.pdf
Gray-Hoverman
https://www.idc-online.com/technica...ing/Gray_Hoverman_the_wideband_TV_antenna.pdf
