Using Transistor as a shorting switch
Ian0
Joined Aug 7, 2020
13,238
I think your confused about something, if you look at the waveforms posted above. I'm talking about 250 max
Really? Most sparking plug ignition systems work at 10kV and above. The voltage output from a magneto varies proportional to speed - that's why engines with magnetos are difficult to start.
dandy1
Joined Sep 30, 2017
178
Let's start from the beginning. My GENERATOR has a dual coil ignition, primary and secondary. The primary coil is induced by a magnet passing a core within the primary causing a current to flow which creates a magnetic field. This magnetic field is then intersected by the secondary coil, which overlaps the primary causing a greater current within. Now the research I've done suggests that the voltage in the primary coil gets to about 500v max. Now I can't be sure of the voltage I am getting but my scope suggests about -208v.
These ignition systems are somewhat different to your typical automotive ones.
Ian0
Joined Aug 7, 2020
13,238
So it's a Low tension magneto. You said that there wasn't a lower voltage coil.
So the primary is about 500V, much the same as the voltage on an automotive ignition coil primary.
In that case, you should be able to short it out with a 800V triac/opto triac combination.
They can't be that much different as they use the same sparking plugs, the same fuel and the same compression ratios.
BobTPH
Joined Jun 5, 2013
11,620
But if if it doesn’t need to be turned on and off as he stated here:
BobTPH said:
It sounds like you want to turn the clamping on and off. Why?
No I very much need the clamping to stay in place
Then a simple diode does the same thing.
BobTPH
Joined Jun 5, 2013
11,620
I thought he was trying to pass on the positive part of the signal while clamping out the negative part, this after a resistor from the coil.
If indeed he is trying to stop the engine, then the switch must be directly across the coil. So why didn’t the transistor simply explode with 500V across it with no current limiting?
@dandy1: you need to explain better what you are trying to accomplish, and how it is connected to the ignition primary.
dandy1
Joined Sep 30, 2017
178
The fact that the transistor hasn't exploded is that I simply think that there is not much energy as you might expect, please look at the waveform.
The signal is conditioned first by a reversed diode that blocks the positive voltage. At this point there is only negative pulses coming from the primary. How it's connected to the primary I have no idea as that part is not accessible. This wire(from which I get the signal) is dedicated solely for the purpose of grounding the signal to the chassis.
I want to short the signal to ground after the reversed diode.
