Bordodynov
- Joined May 20, 2015
- 3,428
My circuit works well only with a small output signal. I do not understand why you put (use) an attenuator. You can also change the transmission factor for a triangular signal.
Because i want to use the resistor divider to generate the +-0.6mV and in LTspice it works well. But in the experiment it didn't work and generate a strange wave. I don't know why.My circuit works well only with a small output signal. I do not understand why you put (use) an attenuator. You can also change the transmission factor for a triangular signal.
