Using MAX038 to generate triangular waveform with 2MHz
Status
Not open for further replies.
JackieChan
Joined Sep 17, 2017
50
Hello everyone,
now i want to use MAX038 to generate the triangular waveform with 2MHz. And i need your help.
At first i want to test the circuit in a simulator such as LTspice or TINA, so i need the spice model of MAX038. I have try to find it in Maxim website but there is no any more.Can anyone know where can i get the model of MAX038?
And the amplitude of MAX038 output is +-1V, and i need maybe +-50mv, so i need also to amplifier it. Do you know how?
Thanks a lot for your help in advance.
Jackie
simozz
Joined Jul 23, 2017
170
The MAX038 is out of production since many years but you can still find on sale (e.g. on futurlec). Maxim doesn't have a spice model for it, I asked them before building my own signal generator with this IC.
However if you want to build a triangle wave generator you can set it up with a few op amps (a relaxation oscillator followed by an integrator) which is definitely a cheeper solution than using a MAX038 which can cost approx. 20 $.
To achieve the attenuation you request, use a inverting amplifier.
A voltage divider can do the job but the load can influence the output voltage so it's a bad idea.
simozz
ScottWang
Joined Aug 23, 2012
7,505
±50mV are very tiny, are you sure you want that values of voltage?
±50mV or ±50V?
If you need ±50V then you can see the totem pole circuit.
How is the frequency, fixed on 2Mhz or variable frequency?
If the frequency is fixed then you may check below link to be your reference.
triangular waveform with 2MHz using op amp
JackieChan
Joined Sep 17, 2017
50
simozz
Hi Simozz,
Thank you so much for your help!
If i use MAX038, do you know where can i get the spice model of it?
If i don't use MAX038, do you know which circuit can i use to generate the triangular waveform with 2MHz, +-50mV?
Best wishes,
Jackie
JackieChan
Joined Sep 17, 2017
50
±50mV or ±50V?
Thank you for your answer.
I need the +-50mV triangular wave as Dithering signal.The frequency is higher than 1MHz and variable.
Do you know any circuit to generate it, if MAX038 is not possible any more.
Thanks a lot.
Jackie
MrAl
Joined Jun 17, 2014
13,801
Thanks a lot.
Jackie
This sounds like an ADC project perhaps?
There are several circuits online that generate a triangle, maybe someone can post one here. They basically use a comparator and op amp integrator to generate a triangle. The frequency is variable via change of resistance or capacitance. I dont know if you need voltage control instead but you might provide more info about what this is to be used for.
Alec_t
Joined Sep 17, 2013
15,156
What is the dither voltage being applied to? Generating an approximation of a 2MHz triangle will be far easier than generating an accurate triangle.
DickCappels
Joined Aug 21, 2008
10,661
You want to make a 2 Mhz, 50 mv P-P triangular wave? Just make one of these oscillators and follow it with a single pole RC filter. That should give you a beautiful triangular waveform for less than US$1.
Edit: If you use 11k and 1000 pf you will get a P-P output that is approximately 1% of the power supply voltage (50 mv P-P with a 5.0 V supply) or 5.6k for 2%. That should give you an idea of how to modulate the amplitude should you wish to do so.
ian field
Joined Oct 27, 2012
6,536
ScottWang
Joined Aug 23, 2012
7,505
Thanks a lot.
Jackie
How is the frequency range, exp : 0~2Mhz, 200Khz~2Mhz?
Did you see the links that I made in the #3 -- triangular waveform with 2MHz using op amp.
Is this a homework or just your personal hobby?
MrAl
Joined Jun 17, 2014
13,801
Reference quote:
MrAL said: "Perhaps to be used with an ADC?"
If you using ADC then how 2Mhz become digital?
If you using DAC, the output is 2Mhz then how is the input frequency?
Hi there Scott,
Well a triangle wave could be used as a well controlled ADC dither source.
ScottWang
Joined Aug 23, 2012
7,505
Reference quote:
Hi there Scott,
How is the input signal of your "A" in ADC?
How does the D(maybe 8 bits or more bits) become triangle wave, are you trying to use another DAC or use like R-2R ladder circuit?
MrAl
Joined Jun 17, 2014
13,801
Hi again Scott,
The triangle would be used to dither the input to the ADC and thus would be one way to achieve practical oversampling. The triangle is mixed with the normal ADC input.
MrAl
Joined Jun 17, 2014
13,801
Could you draw a block diagram to show your idea?
Well, the only difference is that a low level triangle is added to the normal ADC input which is the input to be measured, and the output of the summer goes to the ADC. It's that simple of a block diagram.
So nothing changes but we add:
1. A low level triangle.
2. A summer, such as with an op amp.
Status
