twoway intercom using ic tlv2374
sami30030
Joined May 15, 2025
10
sir/madam
i want circuit digram of twoway intercom using ic tlv2374 and also want noice cancllection in this circuit .
please help me
28,279
sir/madam
please help me
Welcome to AAC, an extended on-line community that holds access to a vast amount of experience and insights. Quite a few of the folks here are engineering professionals, including some who provide engineering commercially, as a fee for service business.
This Is An interesting request! Can the TS provide the data sheet for that IC? The "TLV2374" device, so that we do not need to research it??
AND in addition some description of just what functions of that device would be utilized, and in what sort of arrangement.
KeithWalker
Joined Jul 10, 2017
3,618
Why do you want to build this? Is it a school project? Are you planning on marketing the finished product? The reason makes a difference to what we can do for you.
28,279
I suspect this gentleman wants to do it for himself, DIY is never going to be as good, IMO.
I totally disagree about DIY never being as good. The exceptions being if the DIY'er lacks skill, ability, knowledge, and resources.
I have seen and understood the simple scheme for creating a non-switching, full duplex, intercom system. But if the TS was not willing to do the research to find the circuit, that is unfortunate. The first version I saw used octal tubes, which were current technology at that time. So the concept and the method have been around since the mid 1050's.
Ian0
Joined Aug 7, 2020
13,278
Most of us on this forum are electronics design engineers. So if we make something for ourselves, it is DIY. If DIY is never as good as bought, should we just give up our jobs?
LowQCab
Joined Nov 6, 2012
5,102
A DIY Project quite often has the advantage of not having so much concern for
fitting into a particular market, or a particular cost-target requiring maximum profit.
LowQCab
Joined Nov 6, 2012
5,102
i want circuit digram not datasheet i allredy have that
You haven't stated how You expect the Intercom operate, or in what type of environment.
How high is "up" ?????
Are You married to the Op-Amp that You provided a number for ?,
it's not a particularly great choice for a simple Intercom-System.
What will be Powering this Intercom ?
Do You have limitations as to the type of Cable connecting the 2 Stations ?
Cat-5-Cable is the most convenient and versatile choice, and is very inexpensive.
Do You want a Push-to-Talk-Button on either end ?, this is very important !!!
There are a large variety of configurations possible.
28,279
What sort of "technician" IS the TS?? How much electrical or electronic knowledge and experience do they actually have????
Will the TS be able to follow a circuit schematic that is not a wiring diagram??
All but the very most basic, non-amplified, intercom circuits are a bit complex, with more than a single current loop. The full-duplex, non-switching scheme is probably beyond a lot of folks.
28,279
With the amount of detail that the TS has left us, there is no reason to spend any time thinking about this request.
Is the intercom to be "push to talk"?? Head-sets, or speakers?? Battery powered or sound powered or mains powered??
Should it be wired or wireless?? How much noise to be cancelled?? Multi-station or just a single pair??
28,279
Do you have two of them connected together?? It is intended to only output the signal arriving from the other identical system.
The mode id indeed full duplex and so it will not amplify what enters by the microphone port.
28,279
THE CIRCUIT IN THE ATTACHMENT TO POST #14 IS what I was referencing earlier.
It is a valid concept and it works, BUT it more than doubles the complexity because every station must include that whole circuit.
What the TS is actually doing for the results they are getting is not at all clear. I await the answers.
28,279
How are you testing the circuit??? Do you have two of the assemblies completed and then connected to each other??
Please explain what you are doing that does not work.
sami30030
Joined May 15, 2025
10
I have completed that circuit on zero pcb and i make this two pics then i give both pcb supply of 10v to 12v then i connect audio line in between them , but when we speak on mic sound is not transfering to other side pcb it was sending back to the pcb on which mic we are speaking .
