Hi
I am having a problem that leaves me baffled.
I have one of these cheap RC receiver modules
https://www.ebay.co.uk/itm/231418644091
Here is a picture
They are pretty simple - when a button is pressed on the transmit fob, the voltage on the corresponding receiver pin goes high. When the button is released the output goes low. They run on 5V.
I am trying to use it to power a rotary actuator that draws about 500mA peak. It is a shape memory alloy actuator so not quite like a motor. They are here http://www.migamotors.com/index.php?main_page=product_info&cPath=1&products_id=30
I am driving the actuator through a stp36nf06l mosfet, in the usual configuration - output of RC receiver module to gate, 100k resistor between gate and source, source to ground, and actuator between drain and VCC
Now here's the problem. When everything is connected, as soon as I press the button on the fob the output on the receiver goes high, and the actuator starts to move, but straight away the voltage on the output pin drops and the actuator stops. If I keep the button pressed, it tries again, so I get a kind of stuttering motion.
I am running all this at the moment from the bench PSU with plenty of power, and the voltage to the receiver module does not drop.
I can use the same configuration to operate the actuator from the output pins of an Arduino Uno with no problem so I don't think the problem lies with the actuator or mosfet circuit
I even tried replacing the mosfet with an optocoupler which draws negligible current but the same problem occurs. Basically as soon as any current is drawn from the power source, the receiver stops functioning, even though there is plenty of current available. (I mean, if the circuit can run from a UNO, why not from this unit?)
The only way I can fix it is to run the actuator from a separate power source but I don't want to have to do that.
Any ideas, please?
Here is a picture
Any ideas, please?
