Hi, I'm trying to simulate this circuit but I need to use the ad629 for it to work. I have tried to use the .lib and .inc but has not work for me. http://www.analog.com/media/en/technical-documentation/data-sheets/AD629.pdf for datasheet and for the models http://www.analog.com/en/design-center/simulation-models/spice-models.html
I'm new to this so I would appreciate if someone can tell me what I'm doing wrong or why is it not working. Thanks!
This is the text file that I'm trying to use/call:
Code:
* AD629B--Typical values SPICE Macro-model
* Description: Amplifier
* Generic Desc: Bipolar, Diff Amp, Hi CMV to +/-270V
* Developed by: JG/ADI, TRW/ADI
* Revision History: 08/10/2012 - Updated to new header style
* 2.0 (11/2003)
* Copyright 2000, 2012 by Analog Devices, Inc.
* Refer to [URL]http://www.analog.com/Analog_Root/static/techSupport/designTools/spiceModels/license/spice_general.html[/URL] for License Statement. Use of this model
* indicates your acceptance with the terms and provisions in the License Statement.
* BEGIN Notes:
* Not Modeled:
* vnoise, not included in this version
* inoise, not included in this version
* distortion is not characterized
* Parameters modeled include:
* Nominal Gain
* CMRR vs. Frequency
* Output Volatge Swing
* Iquicent Swing
* closed loop gain and phase vs bandwidth
* output current and voltage limiting
* offset voltage (is non-static, will vary with gain)
* ibias (again, is static, will not vary with vcm)
* slew rate and step response performance
* (slew rate is based on 10-90% of step response)
* current on output will be reflected to the supplies
* cmrr is characterized in this version.
* END Notes
* Node assignments
* non-inverting input
* | inverting input
* | | positive supply
* | | | negative supply
* | | | | output
* | | | | | REF(-)
* | | | | | | REF(+)
.SUBCKT ad629 20 10 99 98 70 1 5
***EXTERNAL RESISTORS( INTERNAL TO DEVICE)***
RF1 2 70 380E3
RG1 10 2 378.7E3
Rneg 2 1 21.11111E3
RG2 20 9 378.7063E3
RpoS 9 5 20E3
***input Stage***
Ccmmr 2 0 25E-14
***negative input right side***
Rc1 99 5a 2.54091E3
Q1 5a 2 7 QX
***positive input left side***
Rrc2 99 6a 2.54091E3
Q2 6a 9b 7 QX
***BIAS CURRENT SOURCE***
IEE 7 98 20E-6
***GAIN STAGE***
GM1 1ref 76 5a 6a 3.52E-4
***ZERO/POLE***
RG 76 1ref 8.52273E11
CPZ 76 1ref 5.6E-12
***ZERO/POLE ENDS***
***rail_to_rail clamps***
v1 99 13 1.600000
d1 76 13 dx
v2 12 98 2.210000
d2 12 76 dx
***rail_to_rail clamps ENDS***
***MID POINT REFERENCE RESISTORS***
Rref1 99 1mid 17E3
Rref2 1mid 98 17E3
Eref 1ref 0 1mid 0 1
***MID POINT REFERENCE RESISTORS ENDS***
***INPUT OFFSET VOLTAGE***
Vos 9b 9 .005E-3
*** END OF INPUT OFFSET VOLTAGE***
***OUTPUT STAGE***
D17 76 84 DX
VO1 84 70 .20300V
VO2 70 85 .20300V
D16 85 76 DX
G30 70 99 99 76 20E-3
G31 98 70 76 98 20E-3
RO30 70 99 50
RO31 98 70 50
.MODEL QX NPN ( VA=10000,BF=5000)
.MODEL DX D(IS=1E-12)
.ENDS
