I have a 12v color organ that does not react or operate as it should. I have been testing all of the components to see if they are in working order with a multi-meter. The switch has also been replaced with a working one (temporarily)
I believe that the transistors are bad as all of the contacts are reading on the multimeter. Is it safe to assume they need replacement?
This appears to be a three-channel circuit, so how would I go about purchasing transistors to keep the channels separate?
