Treadmill MC 70 controller starts the motor, then cuts off.
bnaivar
Joined Sep 6, 2018
I'm gutting a treadmill to use the motor on my lathe. Using the directions found in this YouTube video:
I am able to get the motor to start, but after a few seconds I hear the relay click and the motor turns off. I don't want to replace the controller when a fix is possible, but can anyone give me an idea as to where to start?
I can also connect a lower horsepower motor to the same controller and it will not cut off until the smaller motor is about 3/4 speed.
MaxHeadRoom
Joined Jul 18, 2013
30,808
If you used the motor and controller off the same T.M. then motor size should not be an issue, use a incandescent lamp to detect whether it is a time or current issue.
Those are the SCR bridge versions and are generally the easier one to get going.
Max.
