Hi all,
During these quarantine times I have started working out and have a treadmill at home which wasn't really used. Started on it and about a week later it just stopped.
Using YouTube and info here I opened up the case and could see the fuse was blown (F10A250v). I ordered some more and I put a new fuse it. Fired up the treadmill, the belt ran for a second then a small spark and the fuse blew again.
I removed the positive and negative wires and hooked them up to a battery to check the motor. Once I did this the motor ran and the belt was working.
I have no idea what the issue might now be. I'm not very technical in skill here and used this site and online to help me get this far. I have attached pictures to help.
I have also noticed that the new fuse is a F10AL250V not a F10A250V as the original. Does the 'L' make a difference?
Any info would be amazing!!
Thanks
Thanks
