Treadmill NordicTrack 3000L suddenly stopped working and blows fuse on the Power Board
renehasp
Joined Mar 19, 2024
Hi everyone
I have a Treadmill - NordicTrack Powertread 3000l suddenly stopped working and blows fuse on the Power Board.
https://www.manualslib.com/products/Nordictrack-Powertread-3000l-3071189.html
It blows as soon as I turn on the power.
POWER ON (
The 115VAC LED stays ON
All other LEDS are off
Could it be the transformer that is bad and causing the fuse to blow?
These are the fuses I found as a replacement did I purchase the wrong fuse?
"T250mA250V Fuse"
https://www.amazon.com/dp/B0B58B6ZXW?ref=ppx_yo2ov_dt_b_product_details&th=1
As a test, If I put a paper clip in it instead of a fuse it all works.
POWER ON (
9VDC LED is ON
Everything works, but I know it's not safe, so trying to figure this out. Thank you for any possible help. Also, a lot of the parts you can't get anymore, but I love this heavy-duty treadmill, so trying my best to save it.
Thank you
Rene
panic mode
Joined Oct 10, 2011
4,949
what was the rating of original fuse? it should be written on it....
Alternatively take a better shot of fuse holder and any label around it
