Fc = 1/ ( 2 * pi * R * C ) = 0.16/(R*C) = 0.16/( 10Ω* 330uF) = 0.16 / 3.3ms = 48.4848485HzPls. tell how you have calculated Fc of 49Hz with 10ohms internal emitter resistance (re) of the transistor.??![]()
I told you the formula before. The same formula is used to calculate the cutoff frequency of the input coupling capacitor and the output coupling capacitor.Pls. tell how you have calculated Fc of 49Hz with 10 ohms internal emitter resistance (re) of the transistor.??![]()
But why doesn't your teacher teach about this simple and important stuff??I am very thankful for your useful post...!!![]()
Is there any software from which i can connect output directly to computer??
Why do you want to connect the output of a single transistor to a computer?Is there any software from which i can connect output directly to computer??![]()
what does PM stand for?Most Indian schoolkids post the same questions on many Western websites.
They also send millions of PMs.
I don't know, google electronics lectures, videos, there is among others a India educational classes, like college classes, that you can view on line, as there professor is teaching it, these teachers, are teaching modern transistor theory electronics, right down to hybrid parameters and modeling transistor parameters, they are well educated teachers in there field.PM = Private Message, kind of like an e-mail sent directly through the forum.
but eventually realized they must not really have much of an educational system around there,.
I agree,over the years I found nothing beats building your own stuff and failing 90% of the time at first but I've been at this for well over 50 years.
but he jumped in way too early on complex stuff when he really needed to learn about the most simple basics before he advanced to even simple transistor amplification. .
to find it base current, current in (R3-R4) is this right,Before you leap into phase shift oscilators, and darlington configs. and bootstrapping,
It is apparent from the schem. in this post, you are stumbling on getting a transistor biased into its linear region.
Follow these steps to see how this schem. is not designed properly.
First you have 10v. supply.
[(V1 x R2) / (R1 + R2)] = 4.44v. equals base voltage.
Now subtracting Vbe of 0.65v. from this base voltage , you now have around 3.8v., this is the voltage across the resistor labled R4, which is 500 ohms.
Now the current through R4 is (3.8v. / 500 ohms) = 7.6mA.
For first order aproximation, assume that current value to be the current that will also flow through R3, which will produce a voltage drop of, (7.6mA. x 2K ohms) = 15.2v.
You are only using a 10v. supply, so it is impossible to use these resistor values.
If you want a basic approach to this design here is a way to do it.
Kepping your 10v. and using the value of 7mA. for collector current.
Since you are biasing this into its linear region, then use this rule of thumb.
Make the voltage drop 1/2 of the supply voltage, across the collector resistor. So design this with 5v. across R3.
therefor R3 will = (5v. / 7mA.) =~ 680 ohms.
Now to solve for the emitter resistor R4, design this to have 1V. drop across the transistor itself.
That means the voltage that is left will be across R4.
Voltage across R4 = (10v.VCC - 5v.R3 - 1v.transistor) = 4v. left over to be across R4. which is called "VE"
Now with 4v. across R4, VE, you can solve the value for R4, by using this equation, R4 = (VE / IC), where IC was established in the beginning of this excersise to be 7mA.
So R4 = (4v. VE / 7mA. IC) =~ 560 ohms.
Now for this to work, you have to establish the voltage divider resistors that will put a voltaqge at the base to cause the transistor to be turned on, here is how it is done.
Base voltage (VB) = emitter voltage (VE) plus Vbe (0.65v.)
given as VB = (VE + 0.65v.) = 4.65v. which will be applied to the base of this transistor, to make it turn on, and produce close to the current value of 7mA. that this is being designed for.
To solve for the resistors needed to make this happen, you need to use some more equations.
First make R2 to be around 10 times greater than R4.
So R2 will equal 560 ohms times 10, which would be 5.6K ohms.
Now to solve for R1 use these two equations.
Solve for divider current, first, by taking this equation here.
(divider current (ID), equals , base voltage (VB) divided by R2.
given as ID = (VB / R2) = (4.65v. / 5.6K ohms) = 830uA.
Now R1 can be solved by using this additional equation,
R1 = [(VCC - VB) / ID] = [(10v. - 4.65v.) / 830uA.] =~ 6.2K ohms.
Now build this circuit on your computer and check the voltages with respect to ground, at the collector and the emitter and the base, and see if they are close to the calculated values in this excersise.
Once you do that, THEN, follow the same procedure outlined, BUT THIS time make the voltage drop across the transistor to be 2.5v. and solve for the values of the resistors R4, R2, and R1. in that order.
And again simulate it and check the voltages as you did before, then as a final excersise use 2.5v. across the transistor again, but THIS TIME make the collector current (IC) be 10mA instead of the 7mA, you were using, and solve for the resistors R3, R4, R2, and R1 in that order.
Using the same techniques as given above.
Then let us know how you did, post your results for us to evaluate how you did on this.
Then we can show you how to modify these circuits to get voltage gains so it would act as an amplifier.
Yes.to find it base current, current in (R3-R4) is this right?
Simple arithmatic shows the amount of base current: 675uA - 648uA= 27uA.how to know β for this ckt?]
Hi,Yes.
Each transistor has a different β, even if they have the same part number.
This transistor has a base voltage of 648uA x 2.9k= 1.88V then its emitter voltage is about 1.88V - 0.7V= 1.18V then its emitter current is 1.18V/400 ohms= 2.95ma then its collector current is 2.95mA + 27uA= 2.98uA. Then its β is 2.98uA/27uA= 110.4. .
I've seen people go through four years of theory (in all sorts of subjects) yet still not understand a minute of it, they only memorized the formulas, dates or whatever just to pass the tests. Labs in electronics or physics were often a joke as you were paired up into groups and one usually ended up dominating the solution from which the others copied.I understand that you are in 3rd semseter B.tech. By know you should have come across the transistor theory twice, once in your pre-university where they deal with the physics of transistor in depth and then in your 1st semester (or 2nd semester depending on the college) of B.Tech where need of biasing, different techniques of biasing, configuration like cb,ce,cc , stabilizing, cascading etc is dealt in decent depth. All engineering colleges in India should mandatorily be approved by AICTE( All India council of technical education) and their standard text books deal this subject in excess. How is that you have missed all this.
OOps,Hi,
Audioguru,
For the sake of him not getting confused, please rewrite the above, to show him the correct value of the emitter current and collector current.
I know youll see it when you look back over it again.
