This circuit.here is the ckt. pls tell how resistance R3 is working, as the it is shorted by conductor.
Here i design voltage divider bias transistor, pls check!!
The wrong circuit came from his teacher who said his schematic is correct. So the teacher also knows nothing about the basics of transistors.It seems like he needs to learn the very basics of biasing a transistor, before he could even begin to design an oscillator.
Sorry, sir it's my mistake in hurry.Your circuit is drawn wrong and each part has two numbers.
I showed you how to do it. Are you blind?
Maybe your teacher is blind and knows nothing about electronics.
I am not a SIR!Sir, why offset voltage change the output waveform and is the biasing done is correct??
Select the lowest frequency you need at almost full output level. Then learn about the reactance of a capacitor at that frequency. It is an important and simple formula. Ask your teacher.what value of capacitor should be used for coupling??
I already told you that if you add an input coupling capacitor then R3 and R4 bias the transistor wrong so it is almost saturated. R3 and R4 should set the base voltage a little lower which will cause the emitter voltage to be lower and the collector voltage to be higher then the collector can swing more.The Biasing done is correct??
Your circuit was missing an input coupling capacitor so the DC offset voltage of the signal generator was biasing the transistor, not R3 and R4.i want to know on changing the offset voltage the output waveform changes, why??
There is no "bypass capacitor". Hobbiest added an input coupling capacitor and an output coupling capacitor to pass the AC signal but block DC. His 1000uF is much too much capacitance. The formula is C= 1 divided by 2 pi Rf where R is R3, R4 and the input resistance of the transistor in parallel and f is the frequency that is at -3dB.why you have connected large bypass capacitor, how it is calculated??
The transistor should be biased so that its output can swing an equal amount in a positive direction and in a negative direction. But you had the collector DC voltage too low so the transistor was almost saturated. You can increase the collector voltage by increasing the value of R4.why you have said to take voltage across transistor (i.e.) 2.5V??
