ok, i will see more deeply!!
But you have the base voltage of the transistor DC-shorted to ground through the generator because your circuit is missing an input coupling capacitor. Then the transistor is cutoff most of the time.no sir, i have checked the current in voltage divider bias and base current it was higher than base current.
It takes years of experience to learn from what height to drip the solder onto a solder joint.What means 'resistive' solder joint? The bigger the blob the better the job, ey what!
But your transistor is biased wrong anyway so it will be saturated most of the time if you add an input coupling capacitor.
[/QUOTE
My teacher said the coupling capacitors used is for blocking dc and passing ac, how to find transistor biased is in saturated mode not in active region ??
My teacher said the coupling capacitors used is for blocking dc and passing ac, how to find transistor biased is in saturated mode not in active region ??But you have the base voltage of the transistor DC-shorted to ground through the generator because your circuit is missing an input coupling capacitor. Then the transistor is cutoff most of the time.
You need to scroll down to see the schematic and parts list.the link is showing this images!!
what does it mean??
Your schematic shows R3 shorted.here is the ckt. pls tell how resistance R3 is working, as the it is shorted by conductor.
Yes, the circuit you posted is not correct. Audioguru even elaborated on why is it not correct and how to fix it.the circuit i post is not correct??
Which one, exactly? This thread now has 6 pages and many circuits have been posed.Sorry, sir the circuit i postED is given by my teacher in notes. I asked him also he was saying it will work.
